What does the ribbon cable do on the top right of board by the aux?
Hey, can anyone tell me what the ribbon cable on the top of the device by the headphone jack is for? I did the hardware mod of removing the 2 switches, to get video out, then ended up accidentally breaking the clip for a ribbon cable at the top right of the device by the aux port. I think it might control the LCD screen? I tried to fix it, although it still isn't working. I'm almost 100% sure that I got the pins in contact, so does it actually control the LCD or did I mess up somewhere else? Thanks for any help! edit: Just to clarify, when it boots the LCD screen seems to get power because you can see the backlight, but it doesn't display anything.
(07-04-2020, 11:09 AM)Techwizz Wrote: Hey, can anyone tell me what the ribbon cable on the top of the device by the headphone jack is for? I did the hardware mod of removing the 2 switches, to get video out, then ended up accidentally breaking the clip for a ribbon cable at the top right of the device by the aux port. I think it might control the LCD screen? I tried to fix it, although it still isn't working. I'm almost 100% sure that I got the pins in contact, so does it actually control the LCD or did I mess up somewhere else? Thanks for any help! edit: Just to clarify, when it boots the LCD screen seems to get power because you can see the backlight, but it doesn't display anything.
From your description, should be touch panel flex cable. Please noted that LCD and Touch are two panel glue fussed together and each has its own cable. The LCD connector locates at the left of SIM slot.
  Pine phone main board part Generaltuxenburg 1 3,913 07-31-2023, 07:50 PM
  USB C side board out of stock gab 3 5,455 12-29-2022, 11:42 AM
Last Post: fxc
  What Adhesive to buy for daughter board? LogosCoder 1 3,431 11-28-2022, 05:07 PM
Sad Any luck with a Serial Cable? acid andy 3 5,854 10-15-2021, 04:42 PM
Last Post: acid andy
  pinephone circuit board design, conductive parts zetabeta 1 4,022 08-12-2021, 05:28 AM
Last Post: wibble
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 3,335 06-22-2021, 10:03 AM
  Replaced USB-C side board, touch screen goes nuts Zebulon Walton 2 6,061 04-14-2021, 09:50 AM
Last Post: israel
  PinePhone replacement board won't stop vibrating acohl 8 15,359 02-28-2021, 03:36 PM
  Updated board, still have USB C charging problem xonq 7 12,760 01-31-2021, 10:47 AM
Last Post: xonq
  Possibility of a future board revision novhack 3 6,824 01-25-2021, 04:56 AM
Last Post: y2ktibltd
