Possibility of a future board revision
Hey,
I have currently got sucked into the Pinephone world and I love the whole idea. I know that the plan is to support the current version of the phone for a very long time but I still cannot help it to speculate about a possible revision with a "better" SOC. I researched Allwinner products and the A50 chip looks very nice. Very similar package but using 28nm instead of 40nm, higher clock (1.8GHz), up to 4GB of DDR4 RAM.
I guess my question to other users is: Do you think that it's more probable that in the future there will be a board revision with better specs or a straight up completely new phone design?
from my understanding the biggest issue is finding a board with open drivers
From what I understand the biggest issues are mostly with GPU driver blobs. Allwinner A50 has the same Mali GPU as A64 so I guess it could run with the same Lima driver. Those two seem very similar. Allwinner also has A133 in the A series which is currently "the fastest" but that uses some PowerVR GE8300 GPU which I doubt has any open source Linux support.
I'm pretty sure the Allwinner A50 will use a Cortex-A7 cpu, which is 32bit, and IMHO a downgrade over 64bit.  https://linux-sunxi.org/A50
  Pine phone main board part Generaltuxenburg 1 3,913 07-31-2023, 07:50 PM
  USB C side board out of stock gab 3 5,455 12-29-2022, 11:42 AM
Last Post: fxc
  What Adhesive to buy for daughter board? LogosCoder 1 3,431 11-28-2022, 05:07 PM
  How to check hardware revision? jojuma 1 4,958 07-16-2022, 12:28 AM
Last Post: bokomaru
  pinephone circuit board design, conductive parts zetabeta 1 4,022 08-12-2021, 05:28 AM
Last Post: wibble
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 3,335 06-22-2021, 10:03 AM
  WARNING to future users ~ Order yourself a SIM Card Extender Bonesdog 3 7,552 05-03-2021, 10:06 AM
Last Post: Bonesdog
  Replaced USB-C side board, touch screen goes nuts Zebulon Walton 2 6,061 04-14-2021, 09:50 AM
Last Post: israel
  Future plans for hardware daniel_mazurkiewicz 10 19,233 04-09-2021, 01:52 AM
Last Post: nilclara
  PinePhone replacement board won't stop vibrating acohl 8 15,359 02-28-2021, 03:36 PM
