02-27-2020, 06:53 AM
Sailfish install problem.
02-27-2020, 10:58 AM
thx, it's working
03-02-2020, 07:36 AM
For those, who has this problem but do not use mmc* as the SD card name, but SDB, please change your flash-it script:
https://github.com/sailfish-on-dontbeevi...e152da1dcb Totally worked for me, now I have a lightning fast Sailfish OS. Networking does not seems to work yet, but OS itself is working. ![]() Thanks to Adam Pigg for the tip.
03-03-2020, 05:02 AM
new version of the script 0.2 works fine with internal sd-card readers (/dev/mmcblk0)
06-29-2020, 06:33 AM
Is there any reason why a script is required and an actual easy to flash img isn't just hosted somewhere? Those of us on mac or windows machines are basically out of luck.
07-10-2020, 09:15 AM
(06-29-2020, 06:33 AM)patrickjquinn Wrote: Is there any reason why a script is required and an actual easy to flash img isn't just hosted somewhere? Those of us on mac or windows machines are basically out of luck.You can burn another pinephone image on sdcard, and run the script firectly from there. This will install SFOS on eMMC. |
| When mobile data works calls don't with Sailfish OS | albafrati | 0 | 2,972 |
06-25-2024, 09:28 AM Last Post: albafrati |
| Sailfish on PinePhone | PiSe | 4 | 4,947 |
06-17-2024, 05:46 AM Last Post: PiSe |
| Pinephone keyboard with Sailfish fn-keys | idc | 1 | 3,514 |
01-28-2023, 11:48 AM Last Post: idc |
| Using Windows 10 to install SailfishOS | Kimberley van Buyten | 1 | 3,676 |
12-05-2022, 10:36 AM Last Post: Andidoko |
| PinePhone versus Sailfish (Sony/Jolla) | richieeee | 10 | 18,819 |
07-10-2021, 04:18 AM Last Post: acrux |
| Lock screen problem? | undo | 5 | 10,477 |
03-03-2020, 05:00 AM Last Post: explit |
| Sailfish web browser | linux6730 | 3 | 8,927 |
02-25-2020, 05:42 AM Last Post: DrYak |
| Sailfish still supported? | Mangled | 4 | 9,939 |
02-08-2020, 08:22 PM Last Post: Mangled |
