Using Windows 10 to install SailfishOS
Oke, I installed Ubuntu Touch, Arch Linux, Jumpdrive, Multi-distro and Manjaro. Manjaro seems to be the most suitable OS for me, but I want to play with SailfishOS. The SailfishOS on the multiboot doesn't load properly (like most of the loaders don't on the multiboot) so I have to install it by myself. Now here comes the tricky part for me, because I can't find an image, only flash-it.sh that uses another way that, for me, doesn't look familiar what I used to do. I work on a Windows 10, sorry...
Is there an tutorial or easy step by step? I found this in the comments of a YouTube video:
"...Then simply open Etcher and select that Pinephone EMMC from inside etcher, and flash the SailfishOS onto this...."
But the files I found don't even do a thing! Where to find an image?
EDIT: I find another way to make an image in 'raw', so forgot this topic Smile
(05-27-2022, 01:43 AM)Kimberley van Buyten Wrote: Oke, I installed Ubuntu Touch, Arch Linux, Jumpdrive, Multi-distro and Manjaro. Manjaro seems to be the most suitable OS for me, but I want to play with SailfishOS. The SailfishOS on the multiboot doesn't load properly (like most of the loaders don't on the multiboot) so I have to install it by myself. Now here comes the tricky part for me, because I can't find an image, only flash-it.sh that uses another way that, for me, doesn't look familiar what I used to do. I work on a Windows 10, sorry...
Pls share, that script is giving me grey hair .
  flash-it.sh script currently unable to create a SailfishOS image acrux 3 6,928 07-23-2021, 01:06 AM
Last Post: OhneZ
  SailfishOS status/progress? Sombrer0 40 77,442 11-07-2020, 03:52 PM
Last Post: clover
  Repo with flashable SailfishOS IMG files as400 24 43,845 11-05-2020, 03:18 AM
Last Post: LinAdmin2
  Sailfish install problem. pjsf 15 31,275 07-10-2020, 09:15 AM
Last Post: afigegoznaet
  SailfishOS - open source collaboration meeting 19.03.2020 as400 3 8,177 06-30-2020, 09:45 AM
Last Post: patrickjquinn
  SailfishOS - Android App Support as400 15 37,344 05-28-2020, 03:29 AM
