Boot Image Location
Is it possible to change the boot image? if so where is it stored?
What exactly do you mean? The files from the bootloader:
mobian@mobian:~$ dpkg -L u-boot-sunxi /usr /usr/bin /usr/bin/mksunxi_fit_atf /usr/bin/u-boot-install-sunxi64 /usr/lib /usr/lib/u-boot <snip> /usr/lib/u-boot/pinephone /usr/lib/u-boot/pinephone/sun50i-a64-pinephone-1.0.dtb /usr/lib/u-boot/pinephone/sun50i-a64-pinephone-1.1.dtb /usr/lib/u-boot/pinephone/sun50i-a64-pinephone-1.2.dtb /usr/lib/u-boot/pinephone/sunxi-spl.bin /usr/lib/u-boot/pinephone/u-boot-nodtb.bin /usr/lib/u-boot/pinephone/u-boot.bin /usr/lib/u-boot/pinephone/uboot.elf
The kernel image can be found in /boot (f.e. Image.gz-5.7-pinephone).
What do you want to do if I may ask?
Do you mean "image" as in the binary blob containing u-boot or as in the literal mobian logo you see on boot?
In the first case I think @devrtz has an excellent answer, but on the off chance you meant the logo it's in /usr/share/plymouth/themes/mobian/ . I would recommend making a copy of the theme and modifying that though. You can change the theme in /etc/plymouth/plymouthd.conf .
I think he wants to change the splashscreen and plymouth theme as you said.
(06-28-2020, 06:07 AM)devrtz Wrote: What exactly do you mean? The files from the bootloader:
Just wanted to change the boot logo
(06-28-2020, 09:54 AM)Djhg2000 Wrote: Do you mean "image" as in the binary blob containing u-boot or as in the literal mobian logo you see on boot?
Yeah I meant the boot logo, should have made that clear lel. Thankyou
https://imgur.com/a/D92VflY
  Mobian image for the PinePhone Korfou 2 2,074 04-27-2026, 09:57 AM
Last Post: Korfou
  boot gets stuck shortly after disk decryption vortex 9 12,636 09-11-2024, 05:40 AM
Last Post: normangraves
  cant verify mobian image at website gnugpg penguins_rule 0 2,281 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 11,335 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 5,452 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 2,527 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 3,223 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 5,142 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 3,016 03-06-2023, 12:06 PM
Last Post: freelectro
  Most recent Mobian image or installer image known to work? DrPlamsa 13 16,942 02-26-2023, 11:47 PM
Last Post: SukiiPooru
