#48 Screen Resolution
Just installed #48 and noticed that the screen resolution for the launcher and the notification bar has increased (i.e. displayed smaller). I love it but some people might find it too tiny.
How do you adjust this?
Same here screen resolution changed with #48. No idea how to fix it.
Also affected.
On the stable branch, I was able to use "UT Tweak Tool" from the OpenStore to change Scaling. On the stable branch, after I changed the scaling, when I pressed "Restart Unity 8" it would repeatedly flash the Ubuntu Touch logo so I'd have to force power down the phone. When it came back up, the scaling would be applied.
On the development branch (update #48), I get the same behavior as the stable branch, but after force powering down, the changes are NOT applied.
Maybe related: some icons such as the "back" chevron on several setting pages and the "enter" icon on the keyboard don't render either.
(06-15-2020, 02:30 PM)cpschuster Wrote: Also affected.
49 version is the same , if you change the scaling , you will get enormous apps, let it be ..........
  Screen-off = dead phone okgo 11 22,281 09-27-2021, 07:53 PM
Last Post: jtn0514
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 12,170 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
Sad Help! - Screen blank after update. Zweitaktmotor 4 10,867 07-26-2021, 05:17 PM
Last Post: Zweitaktmotor
  noticable Screen flicker KNERD 0 3,627 01-13-2021, 09:00 PM
Last Post: KNERD
  Copy To SD Card, All I get Is Red Light & Black Screen . . . . NobodyNew1 9 19,978 09-13-2020, 08:59 PM
Last Post: NobodyNew1
  Black screen after pine64 logo Putergenius 2 5,999 07-21-2020, 05:15 PM
Last Post: natasha
  [Possible solution] Stuck on blank screen kugiigi 4 9,950 06-29-2020, 02:51 PM
Last Post: rocket2nfinity
