Ongoing HDMI limited compatability
#21
(04-20-2016, 06:47 AM)rahlquist Wrote:
(04-20-2016, 06:24 AM)tkaiser Wrote:
(04-20-2016, 05:49 AM)rahlquist Wrote: cat: graphics/fb0/modes: No such file or directory
These are relative paths, most likely relative to /sys/class (don't know -- booted the Pine64 a few weeks ago the last time). You might succeed doing a 'find /sys -type d -name fb0' to know the prefix needed to chdir to or create absolute paths.
Thanks, when acting as 'smart hands' and troubleshooting using instructions from another person I tend to be terribly literal. Using the info you provided;
root@localhost:~# find /sys -type d -name fb0
/sys/devices/soc.0/1000000.disp/graphics/fb0
root@localhost:~# cat /sys/devices/soc.0/1000000.disp/graphics/fb0/modes
U:1920x1080p-0
Decided to get a bit more info using another method. I hooked my pi to the monitor and pulled EDID info.
root@raspberrypioldpi:~# tvservice -s
state 0x120006 [DVI DMT (57) RGB full 16:10], 1680x1050 @ 60.00Hz, progressive
root@raspberrypioldpi:~# tvservice -m DMT
Group DMT has 4 modes:
          mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
          mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
          mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
 (prefer) mode 57: 1680x1050 @ 60Hz 16:10, clock:119MHz progressive
root@raspberrypioldpi:~# tvservice -m CEA
Group CEA has 7 modes:
          mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
          mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
          mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
 (native) mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
          mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
          mode 6: 720x480 @ 60Hz 4:3, clock:27MHz x2 interlaced
          mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
Thats the simple stuff, attached is the output of;
root@raspberrypioldpi:~# tvservice -d edid.dat
Written 256 bytes to edid.dat
root@raspberrypioldpi:~# edidparser edid.dat > edid.txt
Also adding full pi serial console boot log.
root@raspberrypioldpi:~# cat /sys/devices/platform/soc/soc:fb/graphics/fb0/modes
U:1680x1050p-0
ATTENTION Moderator Note
Forum doesn't allow upload of files with the extension .log seriously? Might what to address that lol.
I will check out.
#22
(04-20-2016, 08:08 AM)tllim Wrote: I will check out.
tllim while you are at it, can you please check if Allwinner will be adding CEC support for HDMI, for all OS's? It would make life a lot easier.
[   11.102069] [DISP] boot_disp:0x40a
[   11.111232] [HDMI] power vcc-hdmi-33
[   11.120221] [HDMI] cec support = 0
[   11.633738] [DISP] disp_device_attached,line:94:attched ok, mgr0<-->device1, type=4
#23
(04-20-2016, 06:24 AM)tkaiser Wrote: These are relative paths, most likely relative to /sys/class (don't know -- booted the Pine64 a few weeks ago the last time). You might succeed doing a 'find /sys -type d -name fb0' to know the prefix needed to chdir to or create absolute paths.
Yes sorry that should have been
xxd /sys/class/hdmi/hdmi/attr/edid
cat /sys/class/graphics/fb0/modes
(04-20-2016, 06:47 AM)rahlquist Wrote: Decided to get a bit more info using another method. I hooked my pi to the monitor and pulled EDID info.
So why is your RPi not use 1080p @60.00Hz? This is the only physical resolution currently supported with my images.
(04-20-2016, 06:47 AM)rahlquist Wrote: [code]root@raspberrypioldpi:~# tvservice -d edid.dat
So, from the edid data your monitor does not support 1080p @ 60Hz and thus does not work.
See http://paste.ubuntu.com/15954272/ as example for a TV which works without any issue (Toshiba).
#24
(04-20-2016, 11:41 AM)longsleep Wrote: So why is your RPi not use 1080p @60.00Hz? This is the only physical resolution currently supported with my images.
Exactly the point. If a TV or Monitor wont accept 1080p in the Pine just doesnt work. It is not uncommon for 720p devices to not downscale from 1080p. So that is why it doesnt work.
To verify I set the pi to force 1080p out and the screen no longer works.
Is there any possibility of you adding 720p support? That should cover another large portion of devices increasing compatibility?
#25
(04-20-2016, 11:55 AM)rahlquist Wrote: Exactly the point. If a TV or Monitor wont accept 1080p in the Pine just doesnt work.
As expected: Unlike others longsleep updates his images and documents their behaviour. That's the first sentence everyone can read when clicking on the threads describing both his Arch and Xenial image:
Quote:What you get:
- HDMI at 1080p with 60Hz
Now please look at http://wiki.pine64.org/index.php/Pine_A6...ge_Release
HDMI resolution limitation warning disappeared. The 'featured' OS images are outdated, descriptions insufficient and wrong. Links to longsleep's images have been added a few hours ago (before there was nothing, only links to the 'featured' images based on his work). And instead of linking to the threads where everything is explained just links to torrents.
Everything as expected causing frustration and hours of hours of wasted time by countless users (like you for example). And they still do NOT have a quickstart guide where all this is explained. Instead the mess continues. Again: the whole issue is just another example for missing/wrong documentation and therefore surreal expectations.
Did you ever had a look into the BSP kernel sources? Now that tllim announced he got a BSP 2.0 (maybe based on a different kernel version?) everything will get even worse. Dealing with this BSP crap is PITA so I would suspect the real developers will start to focus on mainline kernel from now on. Who wants to throw his own work in the bin just to start from scratch with a new kernel tree (most likely containing the same mistakes as before) since Allwinner feels the need to play 'port and forget' every few months?
And I would suspect in the new BSP both libdram and libhdmi are closed source again. Why should a developer in his own spare time deal with this crap at all? Only since the Pine64 folks raised expectations by removing documentation?
The official Pine64 check list:
  • use Micro USB for DC-IN to encourage users to use Phone chargers, bad USB cables, insufficient 'smart chargers' and the like to reliably prevent their boards from booting
  • do NOT provide a quickstart guide warning for fake/counterfeit SD cards and do NOT explain that Phoenix Card throwing errors is an indication for 'something's wrong', encourage users to use fake/counterfeit cards to get in trouble
  • take a community member's OS images, add some stuff, remove documentation and links to the original to raise expectations (adding XFCE to an image that is know to only show display output at ONE SPECIFIC HDMI resolution and then removing the specific warning is a statement: "Take a look newbies, this is our Desktop Linux image")
  • save a programmable onboard led able to provide user feedback to ensure everyone plagued by the above thinks his board is DOA
and so on... everything as expected: KS backers wasting their time and thinking their boards are bricked. And with every new OS image variant appearing here it will get even more worse.
#26
(04-21-2016, 01:31 AM)tkaiser Wrote: and so on... everything as expected: KS backers wasting their time and thinking their boards are bricked. And with every new OS image variant appearing here it will get even more worse.
Yeah. I had hopes this would work out better for my needs than a pi, unfortunately the KS team made promises that I know Allwinner is just not going to let them deliver on (I thought they had by some miracle already achieved them).
I guess I will just unplug my board and set it on the shelf as a reminder of how stupid it is to believe in an KS..
#27
U:1920x1080p-0
U:1680x1050p-0
I will check out.
The extension .log file now allow to upload.
#28
This is software limitation and also push for more video resolution.
#29
(04-21-2016, 03:37 PM)tllim Wrote: This is software limitation and also push for more video resolution.
Sorry but what  you are saying here isnt horribly clear. Are you saying the limitation of only one resolution is tied to the same issues as the lack of higher resolutions?
#30
I will check out on next week.
  lcd touch screen and hdmi output moreaujacky 2 8,198 10-24-2018, 07:24 AM
Last Post: lisanke
  No HDMI Display need help with correct uEnv.txt settings dkebler 7 16,698 01-11-2018, 02:52 PM
Last Post: dkebler
  HDMI Compatability rahlquist 5 12,906 07-29-2017, 02:32 AM
Last Post: qwerty2002
  No HDMI Output martinarcher 2 9,522 04-28-2017, 07:05 AM
Last Post: martinarcher
  Thoughts on eoma-68 compatability? traverseda 4 10,846 02-23-2017, 06:47 AM
Last Post: lkcl
  Switching from touchscreen to HDMI AUDIOTEK 10 20,516 08-11-2016, 07:41 PM
Last Post: MarkHaysHarris777
  4K HDMI video output medapeta 3 10,010 06-10-2016, 04:36 PM
Last Post: shinobi
  HDMI Issue... LeRoms77 4 11,438 04-19-2016, 02:11 AM
Last Post: LeRoms77
  nexdock (laptop style HDMI display w/ BT keyboard/touchpad) neoaeon 5 12,860 03-10-2016, 07:43 PM
Last Post: hrh1818
  Kickstarter Limited PINE64 T-Shirt - $999 shipping cost to Poland logrus 3 9,433 02-18-2016, 06:53 AM
Last Post: Ghost
