Manjaro ARM for Pinebook
#71
(03-04-2020, 01:14 PM)bvbfan Wrote: I have pinebook 1080p with KDE Neon i just flash emmc card by etcher with Manjaro 19.12 since it does not boot from emmc i decide to dd boot but still no luck. I cannot boot at all, so i should disasembler the panel an trying remove sd card somehow?
Did you generate the image using manjaro-arm-installer? I think the last pinebook img Manjaro released, before moving it from released imgs to being available through manjaro-arm-installer was 19.10. You may want to start with that image and just update it once booted.
#72
(03-04-2020, 01:50 PM)tophneal Wrote: Did you generate the image using manjaro-arm-installer?
No, i just download the emmc, uncompress and flash with etcher (i've using KaOS on my main system)
#73
(03-04-2020, 01:50 PM)tophneal Wrote: I think the last pinebook img Manjaro released, before moving it from released imgs to being available through manjaro-arm-installer was 19.10. You may want to start with that image and just update it once booted.
You're right. I booted successfully from 19.10 and i install it as well, thank you.
Somehow the size of the root is 5.8 GB i don't see ask me to name the its size, the partition is 28GB (as size of emmc 32GB) but only 5.8GB are shown. KPartionmanager shows it's 28GB with 5.8GB allocated how to fix that?
#74
(03-05-2020, 01:21 AM)bvbfan Wrote: Somehow the size of the root is 5.8 GB i don't see ask me to name the its size, the partition is 28GB (as size of emmc 32GB) but only 5.8GB are shown. KPartionmanager shows it's 28GB with 5.8GB allocated how to fix that?
That's odd, usually the image resizes itself on first boot. You can always try booting another linux from SD and using the disk manager to resize your partition. Probably the easiest way since Manjaro uses a single partition you wont be able to unmount and resize while in it.
#75
I downloaded Manjaro ARM i3 20.04 pinebook emmc installer and burned an SD card with Etcher.
Doesn't boot on my Pinebook Pro.
#76
Hi
I have Manjaro on my pinebook,but the microphone is not working
[p@pinebook ~]$ uname -a
Linux pinebook 5.6.0-rc5-1-MANJARO-ARM #1 SMP Sun Apr 5 22:25:55 CEST 2020 aarch64 GNU/Linux
The driver is
FDT /dtbs/allwinner/sun50i-a64-pinebook.dtb
in Alsamixer the mic appears as off
[Image: ee3fa75224c145a98bb7cd422f4ce293]
Tried everything, but I can't get it to work. It does work with Xenial Mate, so mic works.
Any help?
Downloaded 20.08, uncompressed .xz, used Etcher to write SD, booted from SD, but the process did not install on EMMC, but on SD. What did I do wrong? Angry
Addendum: in the initial boot message I get "Loading Environment from FAT... Unable to use mmc 1:1... In:   serial"
#78
(10-12-2020, 09:46 AM)Corkonian Wrote: Downloaded 20.08, uncompressed .xz, used Etcher to write SD, booted from SD, but the process did not install on EMMC, but on SD. What did I do wrong? Angry
Addendum: in the initial boot message I get "Unable to use mmc 1:1..."
try using the 20.04 sd to emmc installer img and updating after installation.
#79
I was using 20.06 and 20.08 from here https://osdn.net/projects/manjaro-arm/st...de-plasma/
20.04? Can't find it...
#80
In an attempt to further address that, I decided to remove all partitions from the built-in eMMC.
Gives me a slightly different Uboot message, but still doesn't install on eMMC but on SD...
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 13,587 05-18-2026, 02:11 PM
  DietPi OS for Pinebook MichaIng 3 15,161 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 98,060 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,187 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 3,966 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 14,991 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 7,751 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 9,933 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 10,607 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 7,931 01-20-2021, 11:18 AM
