slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#71
Thank you guys, now I can access my Rock64.
Any chance that I can establish a compile environment on Slackware to build some service that I need?
(04-10-2020, 02:04 PM)Enig123 Wrote: Thank you guys, now I can access my Rock64.
No problem.
all necessary packages are in category D http://dl.fail.pp.ua/slackware/slarm64-c...slarm64/d/
use the package manager installpkg or slackpkg
update:
slarm64-current-aarch64-base-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz
slarm64-current-aarch64-base-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz.md5
slarm64-current-aarch64-xfce-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz
slarm64-current-aarch64-xfce-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz.md5
kernel 5.6.10
slarm64-current-aarch64-base-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz
slarm64-current-aarch64-base-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz.md5
slarm64-current-aarch64-xfce-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz
slarm64-current-aarch64-xfce-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz.md5
kernel 5.7.15
slarm64-current-aarch64-base-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst
slarm64-current-aarch64-base-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst
slarm64-current-aarch64-xfce-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst.md5
donation   irradium
(08-13-2020, 01:16 PM)mara Wrote: kernel 5.7.15
can someone confirm the operability of this image, on his board version 2.0 is loaded and there is an output to HDMI, but there are also unsuccessful attempts to run on 3 boards version 2.0
thanks.
update
the problem of outputting to the monitor was found out when using the converter HDMI-to-VGA on the 5.7 kernel
donation   irradium
kernel 5.8.3
slarm64-current-aarch64-base-rootfs-20200628-5.8.3-rock64-build-20200824.img.zst
slarm64-current-aarch64-base-rootfs-20200628-5.8.3-rock64-build-20200824.img.zst.md5
donation   irradium
(08-20-2020, 09:48 AM)mara Wrote: can someone confirm the operability of this image, on his board version 2.0 is loaded and there is an output to HDMI, but there are also unsuccessful attempts to run on 3 boards version 2.0
thanks.
For different batch of Rock64 board version 2.0, the software/OS support can be quite different.
As I know, older version 2.0 has serious Ethernet issue with OpenBSD, while more recent batch is well supported. Hope this info helps.
thanks.
Thanks, both the old and the new kernel work on version 2.0 of my board (it's a pity there is no way to check for 3.0), in the old 4.4.y kernel video plays well up to 4K.
donation   irradium
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 18,694 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 1,854 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,128 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,028 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,958 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,231 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,408 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,396 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 86,653 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 110,490 09-01-2024, 06:05 AM
