PinePhone doesn't start anymore
Sad
i can't start my PinePhone. I can't charge battery via USB-C too. Sad
I have make current measurement on USB-C and they says: 5V/0.09A
Have anyone the same problem? What i can do?
Thank you.
That happens if you have drained the battery below its minimum, and the safety circiut turns it off.
It will only charge with around 100mA at first - latter more. Just let it charge for a day.
That method has worked for me with the charger from a Nexus 5X, but it hasn't worked for everybody. There may be some charger interaction we're not fully aware of. If it doesn't work you can get an external universal charger for the battery - there are loads of them on amazon, ebay, ali etc.
Question: does any light turn on when the Pinephone is charging?
No, the light doesn't come on when it's charging. Some indication would be really useful, but there isn't any.
(04-29-2020, 10:20 AM)leibide Wrote: Question: does any light turn on when the Pinephone is charging?
No...nothing.
(04-29-2020, 03:25 PM)wibble Wrote: No, the light doesn't come on when it's charging. Some indication would be really useful, but there isn't any.
its right. but if you charging, the phone will boots automatically ... but not my phone.
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 2 5,466 07-09-2025, 02:04 PM
Last Post: georgegohl888
  Modem Issues with the Pinephone Temmie19 5 3,033 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 2,120 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone + Keyboard for sale, little use ruemoo 9 4,448 06-10-2025, 09:25 PM
Last Post: skaffi
  Pinephone not booting sd card... bruv 1 1,624 03-25-2025, 08:51 PM
  Pinephone - broken power button rorus 13 16,656 12-16-2024, 08:32 PM
  various tricks to open the pinephone shengchieh 3 3,452 09-16-2024, 03:42 AM
  my pinephone melted norayr 6 4,851 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 3,237 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 2,789 03-21-2024, 08:52 AM
Last Post: unrznbl
