Netflix, state of the art?
What's the current state of the art for getting Netflix running on various distros, (especially Manjaro)?
If anyone has a reproducible procedure, maybe we can make it public here?
I am currently looking for a solution for this.
I managed to get a docker container with an Armhf Version of Ubuntu running, which opens a new chromium window (because widevine is not supported for aarch64).
Just need to figure out how to install widevine in this docker image.
I'll keep you updated once I have a stable version.
@hthiemann , you may want to check out openSUSE's implementation for inspiration. Instead of docker, I believe openSUSE is setup with systemd-nspawn with the mrfixit's Debian image. I can't recall if Netflix was working there (it's been two months since I've last tried it) though it's something to take a look at.
Device: Pinebook Pro 128GB No:246 / MainOS: Manjaro ARM
Godot and Flutter - creating something can be fun with the right tools!
Another idea, (very speculative, probably dumb), would be to try this:
https://github.com/intoli/exodus
to relocate mrfixit's chromium and widevine.
Hi all,
I managed to get netflix working now. I am just currently lacking some fps (as HW accelaration seems to be unavailable for now). I will have a look into it today / tomorrow.
Will provide you with an update and instructions on how to use it as fast as possible.
(04-19-2020, 01:14 PM)hthiemann Wrote: Hi all,
That's great news! I'm sure  @Luke  and manjaro team members like @spikerguy   will be very interested in your solution.
Why doesn't Manjaro simply provide a 32 bit userland?
(04-19-2020, 05:42 PM)8-bit Wrote: Why doesn't Manjaro simply provide a 32 bit userland?
It's too much effort to maintain and support a second architecture. Having a two of everything isn't an attractive solution - more so when the prize is a small number of DRM services like Netflix.
With widevine, using a container is the best shot we have at something that can be maintained and functional.
Oh, this is great news. That means Spotify will work too right?
I'm eagerly awaiting your solution Smile
Currently hw accelaration is still a missing feature, but I thought I could share my current version with you - maybe someone has an idea how to fix this Smile
Please find my code and a detailled description here: https://github.com/HenningThiemann/docker-chromium-armhf
Essentially, you need to
  • enable XHost Forwarding to allow the docker container to spin up a new XFrame Window (xhost +local:docker)
  • create a new docker volume to persist your chromium settings (docker volume create chromium_home)
  • spin up the container with the following command
    docker run --rm --privileged \ -e DISPLAY=unix$DISPLAY \ -v chromium_home:/home \ -v /tmp/.X11-unix:/tmp/.X11-unix \ -v /dev:/dev -v /run:/run \ -v /etc/machine-id:/etc/machine-id \ --ipc=host \ hthiemann/docker-chromium-armhf
  • Tested with netflix and spotify, both working
  Funny Conky like script to monitor your PBP state as400 1 5,740 08-19-2020, 12:57 PM
Last Post: xmixahlx
  Netflix on default Chromium/Debian MoonDog 8 17,345 01-28-2020, 04:58 AM
Last Post: simeon
  State of hibernate or hybrid-sleep? Arwen 5 12,383 11-21-2019, 07:51 AM
