Is it possible to avoid interacting with uBoot ?
I recently placed my order for the PBP, before i realized that it may require interaction with uBoot, which can only be done using an external terminal connection with a horribly simplistic usb adapter...
So my question is, is there any way to edit the uBoot configuration outside of uBoot ? I.e. disk editing?
Also, would i need to rebuild and reinstall uboot every time the kernel is upgraded?
I don't suppose there are any tools to manipulate uboot from linux ?
you dont need to do any of that with a reasonable distro.
Manjaro lives a one kernel life, and so does the default debian os.
rolling your own debian you can have multiple kernels, edit extlinux.conf and reboot to a different kernel at will. but you dont have to.
Thanks, that helps to clarify. And the extlinux.conf is in /boot as i understand.
  UBOOT Errors after flashing new os to mmc aechanio 4 9,085 08-18-2021, 07:07 PM
Last Post: aechanio
Question Flashing updated uboot in Manjaro TDC_PBP 5 13,111 05-28-2021, 01:29 PM
  UBOOT - Mainline not booting from SD card / BSP OK Anarethos 1 6,132 01-10-2021, 12:33 AM
Last Post: Anarethos
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 17 32,064 11-19-2020, 03:16 AM
Last Post: FeMike
