UBOOT Errors after flashing new os to mmc
After using the KDE manjaro distribution for a bit I decided to switch to something more lightweight.  i went for the xfce manjaro.
I followed the instructions on this.
https://forum.pine64.org/showthread.php?tid=10403
green booting lights are now amber and after a short moment the uboot menu appears.  This was not happening before on the original factory manjaro install.  Who else has this happened to?
Now instead of booting straight into the operating system it goes to a uboot menu that looks like this
U-Boot 2021,04-3 (May 14 2021 16:20:42 +0000) Manjaro ARM
SoC: Rockchip rk3399
Reset cause: POR Model: Pine64 Pinebook Pro
DRAM: 3.9 GiB
PMIC: RK808
MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhciefe330000:0
Loading Environment from SPIFlash... SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
OK
In: serial
Out: vidconsole
Err: vidconsole
Net: No ethernet found.
starting USB...
Bus usb@fe3a0000: USB OHCI 1.0 Bus usbefe3e0000: USB OHCI 1.0
scanning bus usbefe3a0000 for devices... 2 USB Device(s) found
scanning bus usbefe3e0000 for devices... 3 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot: 0
I want to make the pinebook boot like it used to. Directly into manjaro and with green lights.
How can I configure Uboot to automatically boot the distribution i have flashed on the mmc of the pinebook and get rid of the boot prompts as well as the amber boot light ?
please help if you can thanks.
That thread you linked has an older manjaro img linked in it. try flashing this img: https://manjaro.org/downloads/arm/pinebo...-pro-xfce/ it's straight from Manjaro and more up-to-date. You should be able to boot right into the OS with it.
(08-17-2021, 08:06 AM)tophneal Wrote: That thread you linked has an older manjaro img linked in it. try flashing this img: https://manjaro.org/downloads/arm/pinebo...-pro-xfce/ it's straight from Manjaro and more up-to-date. You should be able to boot right into the OS with it.
I used the current release.
It does boot to the os just fine.  You have to wait 3 seconds with the uboot message on without touching any keys.
I just want to have it directly boot the os not to go to this screen at all with the uboot messages and also i want the green light not the amber one to be working.
does anyone know about this?
You can try a different U-Boot (older or BSP).
I think there is a way to disable the boot screen, it think it was discussed somewhere on the Manjaro ARM forum.
(08-18-2021, 04:55 AM)jiyong Wrote: You can try a different U-Boot (older or BSP).
great idea, using your reply i found this page
https://github.com/manjaro-arm/pbpro-bsp...s/releases
I will flash the original factory image... instead of the most recent MANJARO arm pbpro release.
I shall let you all know what happens.  ty.
  2TB SD Card Write Errors jiacovelli 3 4,415 06-02-2023, 06:13 PM
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 6,094 10-31-2022, 10:14 AM
Big Grin PinephonePro can't Flashing to the eMMC ricardo 1 3,821 07-31-2022, 04:04 PM
Last Post: wpeckham
  Ungoogled Chromium on a Pinebook Pro won't run - OpenGL errors? pinemouth 2 6,784 12-09-2021, 02:23 PM
Last Post: pinemouth
  u-boot flashing problem dex357 2 6,370 11-27-2021, 04:13 AM
Last Post: dex357
  Power LED flashing red/green... appelgriebsch 3 10,690 09-05-2021, 07:59 PM
Last Post: dealie
Question Flashing updated uboot in Manjaro TDC_PBP 5 13,753 05-28-2021, 01:29 PM
  Freeze with flashing light wpeckham 2 7,428 01-31-2021, 12:44 PM
Last Post: wpeckham
  UBOOT - Mainline not booting from SD card / BSP OK Anarethos 1 6,409 01-10-2021, 12:33 AM
Last Post: Anarethos
  eMMC Trouble After Flashing WRONG Image balin 7 15,352 12-29-2020, 04:24 PM
