PinePhone UART
How would I connect to the PinePhone's serial console from linux?  I have the USB to headphone jack converter, and killswitch 6 is flipped off, but I'm a bit lost on where to go from there.
(02-13-2020, 06:59 PM)bobbbob Wrote: How would I connect to the PinePhone's serial console from linux? I have the USB to headphone jack converter, and killswitch 6 is flipped off, but I'm a bit lost on where to go from there.
Personally, I use minicom, a pretty easy to use serial communication program. The steps I went through are as follows.
  1. Install minicom. On Debian it looks like this:
    sudo apt install minicom
    If you're on another distro it should be a very similar command
  2. Add your user to the dialout group
    This step is so that you have access to the serial console without root, run
    sudo usermod -a -G dialout $USER
    Then logout and log back in for this to take effect
  3. Plug in your serial cable
    Plug in both ends and then run
    sudo dmesg
    it should say something similar to
    ch341-uart converter now attached to ttyUSB0
    near the bottom of the output. This means that the adapter was recognized and assigned to a tty. pay attention to the ttyUSB0 part, you use it next.
  4. Start minicom
    Start minicom with
    minicom -s -D /dev/ttyUSBx
    but replace the x with whatever you got in the last step. (if you got 'ttyUSB0' then enter that, 'ttyUSB1' enter that etc...)
    You should be greeted with minicom's main menu. From here navigate to 'Serial port setup' and hit enter. Next press E and make sure that you set the speed to 115200, parity to none, and data to 8. Once that's set, hit enter to save it and then change 'Hardware Flow Control' to No. Now you can leave that menu and go to 'Exit'. It should take you to the terminal screen that you'll use to interact with the adapter.
  5. Enjoy!
    Now would be a good time to turn on the phone and you should see a bunch of text come up in minicom, that's the pinephone's boot process!. Depending on what OS you have installed (ie postmarketOS) it may drop you into a login screen where you can login and get access to a shell on the phone.
If any of this was confusing or isn't working let me know and I'll try my best to help you out.
You'll need a serial terminal application such as minicom, cutecom, gkermit, gtkterm etc. to interact with it. Connect to whatever the usb serial device appears as - probably /dev/ttyACM0 or /dev/ttyUSB0. Many of the USB serial devices auto-sense the connection parameters, but you might need to enter them manually. Mine should arrive in a few hours so I might be able to offer more detail after that if you're still having trouble.
Edit: connection details in the postmarketOS wiki
if that is the same infamous adapter as for Pinebook Pro, then don't use it! it has wrong voltage (5V instead of 3.3), look in the PBP forum for details.
ANT - my hobby OS for x86 and ARM.
I could not get it to work at all. Not sure i have the right ttl levels. This is kinda goofy, as rs-232c is +-18v, bastardized down to +-12v on a pc. You can generally get away with +-5v on a short cable. Now I'm thinking this thing might be +3-0v straight ttl. Debating getting the o-scope from the attic, but I'm lazy. I've got an rpi cable, I should prolly put a meter on it, at least..
Finally, when the dip is thrown for serial, and I had a sim in the wifi refused to work. As it is the wifi is flakey, the usb-c will not take a kb, and I'm not up for much on the soft kb's, my fingy's are fat. It's all pretty close, we may just need to be patient while the various hardware drivers are cleaned up. I use ckermit on the linboxen for this type stuff. Nice and easy to send files old school.
(02-13-2020, 09:54 PM)hnaguski Wrote: snip
Yep, this worked perfectly. Thanks!
(02-13-2020, 11:37 PM)z4v4l Wrote: if that is the same infamous adapter as for Pinebook Pro, then don't use it! it has wrong voltage (5V instead of 3.3), look in the PBP forum for details.
I'm not using the one from the store, I used one from Amazon. In case someone wants to know which one, it's this . I hooked some wires from it to this.
(02-14-2020, 12:40 AM)bobbbob Wrote: Yep, this worked perfectly. Thanks!
Great, good luck in your endeavors!
  Recycling pinephone as home server mdk 3 498 11-12-2025, 11:18 AM
  Pinephone + Keyboard for sale, little use ruemoo 10 5,876 10-07-2025, 07:36 PM
Last Post: PinePhoneProUser
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 2 5,907 07-09-2025, 02:04 PM
Last Post: georgegohl888
  Modem Issues with the Pinephone Temmie19 5 3,853 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 2,662 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 2,041 03-25-2025, 08:51 PM
  Pinephone - broken power button rorus 13 17,840 12-16-2024, 08:32 PM
  various tricks to open the pinephone shengchieh 3 3,984 09-16-2024, 03:42 AM
  my pinephone melted norayr 6 5,528 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 3,695 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
