01-31-2020, 02:53 AM
(01-30-2020, 03:45 PM)logicprobe Wrote: Same here. Living with it.
Me too!
Still a happy Pinebook Pro customer...
crocky
Trackpad lack of fine movement and overrun ruining experience.
01-31-2020, 05:09 AM
(This post was last modified: 01-31-2020, 05:13 AM by mamboman777.)
I am having the same issue on my ANSI PBP. I'm also having trouble getting "disable while typing"working in every distro except the default Debian. It didn't work in Bionic and it's not working in Manjaro KDE, and yes, I have applied the update.
01-31-2020, 07:41 AM
(This post was last modified: 01-31-2020, 07:42 AM by jackhumbert.
Edit Reason: tab
I was messing around with synclient a bit, and found adjusting the MinSpeed setting to help out quite a bit with getting more precision - I'm not sure if it's the recommended way of doing it, but adding this to /etc/X11/xorg.conf allowed it to persist over reboots (in X11):
Code: Section "InputClass"
Driver "synaptics"
MatchIsTouchpad "on"
Option "MinSpeed" "0.25"
EndSection(01-31-2020, 07:41 AM)jackhumbert Wrote: I was messing around with synclient a bit, and found adjusting the MinSpeed setting to help out quite a bit with getting more precision - I'm not sure if it's the recommended way of doing it, but adding this to /etc/X11/xorg.conf allowed it to persist over reboots (in X11): If I don't have /etc/X11/xorg.conf in Debian Bullseye?
PBP ISO / Debian Bullseye (unofficial installer)
02-01-2020, 01:28 PM
(This post was last modified: 02-01-2020, 01:30 PM by Der Geist der Maschine.
Edit Reason: typo
02-01-2020, 03:52 PM
I can confirm that the minspeed setting is very helpful, even though I'm not using the alternative firmware. I'm using the update that was supposed to come on the ANSI devices but didn't. Grabbing screen corners is still a little tricky (I've been using trackpoints on my home and work computers for a decade so maybe I just need practice), but much easier than before. uMatrix is also much easier - those top/bottom buttons are a good test!
02-01-2020, 04:15 PM
(01-31-2020, 07:41 AM)jackhumbert Wrote: I was messing around with synclient a bit, and found adjusting the MinSpeed setting to help out quite a bit with getting more precision - I'm not sure if it's the recommended way of doing it, but adding this to /etc/X11/xorg.conf allowed it to persist over reboots (in X11): Thank you so much! The touchpad is usable now. Not perfect-perfect, but I can actually use it for other stuff than scrolling. Amazing! (01-31-2020, 07:41 AM)jackhumbert Wrote: I was messing around with synclient a bit, and found adjusting the MinSpeed setting to help out quite a bit with getting more precision - I'm not sure if it's the recommended way of doing it, but adding this to /etc/X11/xorg.conf allowed it to persist over reboots (in X11): I've built on your settings a little and have found these to be very good: synclient MinSpeed=0.25 synclient FingerLow=30 synclient PalmDetect=1 synclient VertScrollDelta=64 synclient HorizScrollDelta=64 'FingerLow' has the same value as 'FingerHigh' in my config (30). I believe it helps reduce mouse movement as you lift your finger, but I'm not sure if synaptic works like this. Anyway, I find this config to be comfortable for daily use. I'm still trying to find out how to stop the cursor from jumping around, whenever you put down the finger. Let me know if anyone finds out some even better settings!
02-02-2020, 12:54 PM
my sway config has a basic config with good results: (sway-git, mesa-git, debian sid arm64)
input "9610:30:HAILUCK_CO.,LTD_USB_KEYBOARD_Touchpad" { dwt enabled tap enabled natural_scroll enabled middle_emulation enabled }
02-02-2020, 02:31 PM
I tried to make these changes, but I think my x crashed. I ended up with a cursor. Using Manjaro. Trying to restore from SD, now.
