Virtualization on the PinebookPro
Starting a thread on Virtualization technology possible on the PinebookPro
Wrote a summary on how to use
KVM accelerated qemu-system-aarch64
Non aarch64 qemu-system-xxxx   (powerpc, powerpc64 ... can be anything else really  like i386 and x86_64)
SimH (VAX - OpenVMS and Ultrix UNIX + 4.3BSD)
Hyperion - Hercules (SystemZ Mainframes )
https://astr0baby.wordpress.com/2020/01/...alization/
https://astr0baby.wordpress.com/2019/12/...64-part-1/
NICE!!! didn't expect it to be possible to run a "windows" VM
Awesome articles, thanks for sharing!
Have you tried GPU passthrough on the PBP? Will it work?
(01-15-2020, 11:17 AM)qeek Wrote: Awesome articles, thanks for sharing!
Did not try , not sure it would even work on aarch64
im trying to run the win10.iso for the hell of it, first of all i changed display to vga since i'm on panfrost and it has an issue with fb
second of all, i just get dropped to a uefi shell on boot Sad
(01-28-2020, 05:59 PM)aaspectre Wrote: im trying to run the win10.iso for the hell of it, first of all i  changed display to vga since i'm on panfrost and it has an issue with fb
Are you running Manjaro ? And how did you build qemu ?
Yeah , just checked the it just gets stuck now in the Tiano Core "start boot option" ... Im on panfrost too, I had no idea this could be affecting this, but its rather trange, it worked really well earlier (did not really used it afterwards) I recall Manjaro was on kernel 5.4   (and Im using a same build of qemu from Dec 1 2019)
I will try to reinstall fbturbo and check with that (I have used that primarily a long time before switching to panfrost) but it sounds really strange why should it behave like it does now ...
I will update this post once I know whats going on more ...
Anybody here still has the Manjaro Pinebookpro Preview 4 candidate ? With the Kernel 5.4 https://osdn.net/projects/manjaro-arm/st...preview4/\
I need to see what was changed from 5.4 to 5.5 .. there seems to be some issues (performance wise) with the latest Manjaro 5.5.0 kernel and qemu-system-aarch64 KVM
yeah im on updated manjaro/panfrost
havent tried switching to fbturbo yet but i will tonight and report back if you dont get to it first
OK, so the fault is with the kernel 5.5.0
Just did a clean install of https://osdn.net/projects/manjaro-arm/st....12.img.xz  on a separate micorSD card ,
disabled kernel updates in /etc/pacman.confg
IgnorePkg = linux-pinebookpro
Upgraded the system to latest packages while keeping the kernel 5.4.0-1.5  and Windows 10 arm64 works perfectly again
https://twitter.com/astr0baby/status/122...9774993408
  PinebookPro Display Corrupts/Cuts Out Twig 5 7,073 06-11-2023, 07:59 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 14,793 01-22-2023, 10:05 PM
Last Post: rfm83
  PinebookPro CPU Speed setting therosery 0 2,112 09-07-2022, 05:02 AM
Last Post: therosery
  PinebookPro Build Errors mexsudo 3 6,329 01-30-2022, 08:36 AM
Last Post: mexsudo
  PineBookPro does not charging floppy_rofling 0 5,551 02-03-2021, 05:29 AM
Last Post: floppy_rofling
Heart Zandronum 3.1 on PinebookPro PixelPaintbrush 0 3,251 12-08-2020, 09:59 AM
Last Post: PixelPaintbrush
  Running Libgdx sdk on pinebookpro Nick_dnepr 2 5,976 10-02-2020, 07:56 AM
Last Post: Nick_dnepr
Photo My PineBookPro Dead voodooman 2 5,869 09-14-2020, 09:10 AM
Last Post: Tharadash
