[solved] On default OS (Debian 9), lxqt breaks Chromium
I tried to install lxqt on the default OS of the pinebook pro (Debian 9).
Firstly it's complicated: you have to install openbox in addition to task-lxqt-desktop, which doesn't install by default (!), And you have to go through lightdm-gtk-greeter-settings to add a session selector. In addition, the default configuration is very poor: there are almost no icons.
Second, lxqt modifies the chromium configuration folder, so that it is impossible to connect to your Google account, because the browser is not "secure" (!?)
Fortunately I had synchronize my profile in the Google cloud.
So to solve the problem:
mv ~/.config/chromium ~/.config/chromium.back
restart chromium
Chromium recreated a configuration folder.
Connection to Google is again possible.
Then I syncronized my profile, so I didn't lose my extensions nor everything else.
I just had a security alert that a "new" browser had logged into my account, but obviously it was myself.
Pinebook Pro, standard config (Manjaro)
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,272 08-09-2025, 06:53 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 19,019 06-26-2025, 09:20 PM
Last Post: reukiodo
  Official Debian support moonwalkers 64 124,205 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Debian on Pinebook Pro u974615 7 12,520 03-31-2024, 10:11 AM
Last Post: u974615
  Nethunter default password failed lamlarryyyy 0 4,307 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 12,428 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 23,586 09-07-2023, 09:38 PM
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 4,951 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 5,965 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 6,587 10-19-2022, 03:09 AM
Last Post: alpopa
