Overclock past 1.8/2.2
Hi everyone! I've been testing overclocking on the rockpro64 for some time now, and I've gotten a stable ( I think ) overclock of 1.8/2.2 for the little and big cores.
However, when trying to push them any higher than 1800000000 and 2208000000 in the dts for ayufan-linux-mainline it never works.
I can attempt to set the big core to anything I'd like ( 7.0ghz ) and I get no real warning, and the clock as reported by sysfs is still 2.208ghz
I had to crank the voltage up a good bit to get them stable at this freq anyways so I'm not sure how much further I could go, but I'd like to try.
The thermals with 20mm heatsink + fan are still well within reason too.
(11-03-2019, 01:20 AM)kolbycrouch Wrote: Hi everyone! I've been testing overclocking on the rockpro64 for some time now, and I've gotten a stable ( I think ) overclock of 1.8/2.2 for the little and big cores.
Hi kolbycrouch,
could you please post how you get to 1.8/2.2 please?
Compile your own kernel, old instructions here.
I noticed armbian has CPU freq options built in to armbian-config. I would assume it changes the voltage according to the freq you set?
  Overclock of RAM, CPU and GPU Maxpako 0 3,440 12-20-2023, 09:54 AM
Last Post: Maxpako
  RockPro64 has no white led, nor will it boot past... AnjinMeili 2 4,965 05-31-2022, 09:19 AM
Last Post: Rocklobster
