Some PinePhone questions
I have a few questions about the PinePhone, I’m very excited by what I have seen so far!
Will the brave heart PinePhone be useable as a phone once the software is set up?
Does the PinePhone use microsd for storage? In which case I can buy an sd card with any capacity for more storage space?
I see that it has killswitches for the wifi, microphone, and so on. Are these external buttons or accessed through the UI?
What programming languages can be used to write programs for it’s available operating systems? Would it be the same as developing a desktop Linux application? Could you then use javascript/electron?
Thanks!
(10-02-2019, 08:59 PM)Quddus Wrote: Hi,
Thanks!
The "BaveHeart" release primary focus for early adopter, not normal daily user.
The microSD can be use as storage, we have tested up to 256GB card and should able to expend up to 2TB.
The killswitch locates inside phone, you needs to peel the back cover to access.
(10-03-2019, 09:48 PM)tllim Wrote: The "BaveHeart" release primary focus for early adopter, not normal daily user.
But there will only be a difference in software, right? BraveHeart will get the same hardware as final release?
  Anyone here using a PinePhone as their main phone in 2026? noahclark 0 151 11-15-2026, 03:27 PM
Last Post: noahclark
  Zig booting up on PinePhone WhiteHexagon 0 3,641 07-19-2025, 03:11 AM
Last Post: WhiteHexagon
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 4,105 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Second-Hand PinePhone rdv 9 8,479 01-05-2025, 11:42 PM
  pinephone 3 ideas aular 5 6,944 11-08-2024, 06:35 AM
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 4,320 04-11-2024, 03:10 PM
  Where PinePhone Pro are Made Tony90 1 5,111 01-18-2024, 09:20 AM
  using Zoom on Pinephone andrew907 5 6,417 12-09-2023, 01:26 AM
Last Post: crocspot
  Star64 questions tantamount 3 5,541 05-20-2023, 10:18 AM
Last Post: tantamount
  Does pinephone allow you to repair your own device as easily as fairphone? unix21311 3 6,389 11-06-2022, 10:37 PM
Last Post: Harolddavies0
