Has anyone used an Intel Solid-State Drive 660p Series with the RockPro64?
I'm thinking of getting this NVMe SSD:
https://www.intel.com/content/www/us/en/...eries.html
Looks like a great SSD for the price, but I'm not sure about it because of the Hardware Encryption and drivers.
Driver: Intel® Rapid Storage Technology (Intel® RST) drivers
System BIOS that supports UEFI 2.3.1
Any recommendations if this is not going to work?
Hi @erols ,
Sorry for the late answer, I hope that can help, I got the 660p 2TB and it's working very well on the RockPro64 (armbian) but the RP have a PCIe NVMe v2.0 x4 (not a v3.0).
PCI speed:
v. 2.x (5 GT/s): 2GB/s (×4)
v. 3.x (8 GT/s): 4GB/s (×4)
RockPro64 PCI Bridge: $ sudo lspci -vv
Capabilities: [c0] Express (v2) Root Port (Slot+), MSI 00
                LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L1, Exit Latency L0s <256ns, L1 <8us
I don't know how much the performance is limited as the theoretical read & write speed of this SSD is 1800 MB/s, but below are my tests.
Write tests:
$ sync; dd if=/dev/zero of=tempfile bs=512 count=1024 oflag=dsync; sync; rm tempfile
524288 bytes (524 kB, 512 KiB) copied, 1.08906 s, 481 kB/s
$ sync; dd if=/dev/zero of=tempfile bs=1M count=1024; sync; rm tempfile
1073741824 bytes (1.1 GB, 1.0 GiB) copied, 2.74138 s, 392 MB/s
$ sync; dd if=/dev/zero of=tempfile bs=1G count=4 oflag=dsync; sync; rm tempfile
4294967296 bytes (4.3 GB, 4.0 GiB) copied, 11.5571 s, 372 MB/s
Read tests: (tempfile need to be created with a write test)
$ sudo sync; sudo sysctl vm.drop_caches=3 # reset cache
$ dd if=tempfile of=/dev/null bs=512 count=2048
1048576 bytes (1.0 MB, 1.0 MiB) copied, 0.00843704 s, 124 MB/s
$ dd if=tempfile of=/dev/null bs=1M count=1024
1073741824 bytes (1.1 GB, 1.0 GiB) copied, 1.53206 s, 701 MB/s
$ dd if=tempfile of=/dev/null bs=2M count=2048
4294967296 bytes (4.3 GB, 4.0 GiB) copied, 5.96889 s, 720 MB/s
hdparm test:
$ sudo hdparm -Tt /dev/nvme0n1
/dev/nvme0n1:
 Timing cached reads:   2070 MB in  2.00 seconds = 1035.34 MB/sec
 Timing buffered disk reads: 1876 MB in  3.00 seconds = 625.27 MB/sec
If someone get a nvme SSD with a better quantity & quality vs price, i am looking for suggestion in order to do a backup server.
  Powering two disks from RockPro64 some_pinephone_user 3 6,598 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 3,910 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 15,060 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 4,627 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 50,222 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 4,081 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 6,804 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 17,398 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 4,735 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 15,546 07-18-2022, 10:05 PM
Last Post: zer0sig
