Can Anyone help me install Wine latest on Rock64
I tried every method and I cant get even old wine to install
I get random messages but when I tried to follow the main websites instructions for latest wine I get
sudo apt install --install-recommends winehq-stable
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 winehq-stable:i386 : Depends: wine-stable:i386 (= 4.0~bionic)
E: Unable to correct problems, you have held broken packages.
Been having the same challenge on the RockPro64...
I installed a Debian Buster image...
Anyway, what I've been able to figure out is that the issue is that FAudio is a dependency and it's this standing in the way.
Found that out by apt-get installing each package listed as a missing dependency, down the chain, until I got stuck at libfaudio0 which is not in any repo (source) that I can find so far (i.e. as per the message above, you'd apt-get install wine-stable:i386, which would then list the next dependency, and so on).
So, there isn't a compatible build for FAudio it seems..
I have subsequently read that building wine yourself *could* work; as in, the dependencies don't all have to be met if building from source (some things may not work as expected then of course).
This is a next step I need to take after getting back to a cleaner version of my OS install after all my tweaking...
Did you ever find a workable solution in your case?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,135 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,706 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 95,908 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,988 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,387 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,375 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,913 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,088 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,978 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 117,483 09-01-2024, 06:05 AM
Last Post: RaymondDay
