Rock64 board seems defective, how to confirm?
Hi all!
I have a 4GB Rock64 that has never been able to run any image for more than a few minutes without a kernel panic or a complete freeze. It usually happens within seconds of booting. At first I assumed I had just been unlucky with my image choices, but over the past few days I've gone through probably a dozen different images, Linux as well as Android, and nothing seems to work (though Android images typically run ok right up until the mouse cursor shows up on the screen). I'm booting from sd and I've tried two different cards. Is there anything else I can try that would possibly get this working? Any recommendations for a super-stable image to try? Or something like a memtest image that could help me diagnose the problem?
Unfortunately I bought this last year so it is no longer under warranty, but I would at least really like to confirm that it is a hopeless case before I throw it out the window.
(08-08-2019, 01:35 PM)Josk Wrote: Hi all!
1. Please check your power supply whether still function properly. If you have scope, check the voltage ripple waveform.
2. Run meemtest is a good way to determine whether DRAM still function well.
  Rock64 v2.0 u-boot SPI issues ju0n 0 431 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,789 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 27,205 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 16,122 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 17,899 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,557 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,466 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,548 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,826 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,706 11-28-2022, 02:18 PM
Last Post: Macgyver
