07-11-2019, 12:17 AM
Armbian - Xenial Desktop (Pinebook)
07-17-2019, 12:11 AM
(07-11-2019, 12:17 AM)pineadmin Wrote: Added Armbian Xenial (1080P Pinebook) 5.67 on Wiki and PINE64 Installer The wiki entry for 5.67 lists Armbian as being emmc compatible, yet the last page of this thread and my experience running 5.67 today show that the is not compatible for emmc boot, it cannot even see the emmc. Is that an error on my part?
07-17-2019, 07:56 AM
(07-17-2019, 12:11 AM)PipeItToDevNull Wrote:(07-11-2019, 12:17 AM)pineadmin Wrote: Added Armbian Xenial (1080P Pinebook) 5.67 on Wiki and PINE64 Installer The last armbian stable release (Armbian Bionic with desktop mainline based kernel 4.19.y) is emmc compatible. It is the current system of my pinebook.
07-17-2019, 01:22 PM
Hi guys.
I have one annoying issue, it is reproducible at least for the Armbian Bionic and Manjaro. If I start booting from SD card using these images, at some point (according to Manjaro logs - while starting the kernel) the red led near the charging input starts blinking. It blinks all the time, including when the device is turned off. The worst thing is that it looks like the device stops charging. The only solution I've found for now is to boot from SD card using the Armbian Xenial. I'm not a Linux rockstar, and it looks like an issue related to some low-level operations. Did you observe such issue before, and is there a way to fix it? I do want to use Manjaro, but this is a blocker for me. |
| DietPi OS for Pinebook | MichaIng | 5 | 17,657 |
07-28-2026, 08:02 PM Last Post: tllim |
| Irradium (based on crux linux) Pinebook A64 (aarch64) | mara | 4 | 14,808 |
05-18-2026, 02:11 PM Last Post: mara |
| Armbian broken sometime in the last few months | acruhl | 4 | 6,616 |
05-29-2024, 10:44 PM Last Post: acruhl |
| Slarm64 on Pinebook [Slackware Arm - 64 bit] | KRT | 46 | 105,408 |
09-26-2023, 03:18 PM Last Post: mara |
| Broke pinebook GUI, what to do, fix or install new? | acruhl | 2 | 6,080 |
07-13-2023, 05:43 PM Last Post: acruhl |
| Orignal PineBook | jwp1000 | 1 | 4,579 |
07-10-2023, 07:44 AM Last Post: tophneal |
| Change console resolution (Armbian/bookworm) | jcgraybill | 1 | 7,577 |
06-22-2023, 01:31 PM Last Post: jcgraybill |
| Pinebook no longer boots | rjtanner | 12 | 17,137 |
04-13-2023, 01:09 PM Last Post: tophneal |
| Armbian 22.02 Release Announcement | TRS-80 | 0 | 4,842 |
02-28-2022, 05:02 PM Last Post: TRS-80 |
| Stock Debian on original Pinebook | moonwalkers | 1 | 8,565 |
01-29-2022, 10:37 PM Last Post: cel |
