RETRO-GAMING: UPDATED RELEASE OF RECALBOX FOR THE ROCK64
Has anyone had any success mounting a SMB share for ROMS?
Away
(04-18-2019, 02:56 PM)swanee3d Wrote: Has anyone had any success mounting a SMB share for ROMS?
Never had an issue. Whats the problem?
Hi sorry for the delay I wanted to poke around some more to make sure I wasn't missing something.
I can't seem to get any of the methods of mounting a smb network share to work on the rock64 image but have tested them on the latest recalbox image with a pi3b and they work fine there.
I tried both  manually mounting from the command line and the way outlined on the github of editing the  /boot/recalbox-boot.conf.
If I try to manually mount from ssh I am getting this error in the /tmp/mountNetwork.err file
mount error: cifs filesystem not supported by the system
mount error(19): No such device
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
This is the manual command I used on both platforms
mount -t cifs //192.168.1.xx/recalbox  /mnt -o user=recalbox,password=PASSWORD,uid=0,gid=0,rw
Adding shares in kodi through the ui seems to work fine.
Away
Greeting.....
can anyone tell me how to install retroarch or retropine on pineA64?
Is anybody able to mount remote SMB shared folder from Recalbox?
NOT talking about the access to internal Recalbox shared folder from another computer.
edit: I see that @swanee3d had the same problem.
@Luke , does it work for you? How do you do that?
(07-08-2019, 06:58 AM)Wizzard Wrote: Is anybody able to mount remote SMB shared folder from Recalbox?
As far as I could figure out the newer builds are missing cifs support but NFS works. The original build and the recent official pi versions work as expected so I believe it's a build error.
Away
Ok, so this could be an issue. @Mrfixit2001 , can you please build the next build with CIFS support? Thanks!
New images are now available
Seems that CIFS support is still not present.
Updated Recalbox ver 190719 on Wiki and Pine64 Installer
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 18,712 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 1,868 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,131 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,039 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,964 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,234 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,411 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,396 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 86,696 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 110,536 09-01-2024, 06:05 AM
