Manjaro hangs on boot
So, I have been trying out manjaro but have had nothing but problems ranging from needing to compile from source to install older versions of python to inconsistent booting. The worst has just struck, I cannot boot. If the kernel loads (which is inconsistent) then it runs fine until reaching '[OK] Started Network Manager Script Dispatcher Service' then it attempts to load the DE shows a cursor and then flicks between the two screens. If I try to do ctrl alt f2, it loads the tty but then that screen gets added to the loop making it very hard to use. I will share a video showing exactly what I mean as soon as it uploads.
It seems my post was removed for some reason so sorry if this is a repost. I have manjaro arm installed on an SD card in my pinebook but when booting I get in a loop between the desktop environment starting and the last module being loaded. I have attached a video showing how the bot process looks. I can access tty but it flickers on and off so it is very difficult to get stuff done.
Information Manjaro ARM for Pinebook erchache2000 88 187,196 11-29-2020, 04:36 PM
Last Post: Mr.Fermer
  Latest images from different distros failing to boot from SD card jmonty42 2 7,916 11-17-2020, 09:32 AM
Last Post: pagesix1536
  Plasma-wayland on Manjaro tophneal 2 10,059 09-01-2020, 06:48 AM
  Manjaro sway profile for pinebook e-minguez 3 10,175 07-21-2020, 03:25 PM
Last Post: jezek
  Manjaro instability DAMO238 6 15,227 10-17-2019, 12:55 PM
  Ethernet not found. error during boot Surehand53 1 5,569 07-24-2019, 05:00 AM
Last Post: ObviousHobbit
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 3,650 06-11-2019, 01:36 PM
Last Post: k_mp
  manjaro and qemmu+kvm erchache2000 2 7,342 06-11-2019, 03:11 AM
Last Post: Skywheel
  Blank Screen on Boot MECZero 4 12,223 05-12-2019, 11:54 AM
  how do I boot to SD? (1080) tedder 7 14,133 11-16-2018, 03:15 AM
Last Post: Surehand53
