User Screen Black After Changing Power Settings
Hey! So I ran into a pretty big issue and am in need of some help. I was experimenting with the display brightness in the power settings of my pinebook. In doing so, I turned the screen all the way down and saved. All I see is a black screen now. I’ve restarted the computer and see up until the login screen. After logging into my user account though, the screen is black again. Does any one know how to fix this? Thanks!
(07-03-2019, 12:26 AM)0b51Gekko Wrote: Hey! So I ran into a pretty big issue and am in need of some help. I was experimenting with the display brightness in the power settings of my pinebook. In doing so, I turned the screen all the way down and saved. All I see is a black screen now. I’ve restarted the computer and see up until the login screen. After logging into my user account though, the screen is black again. Does any one know how to fix this? Thanks!
Try the flashlight trick:
https://forum.pine64.org/showthread.php?tid=7323
This worked! Thanks for the advice.
  Hello All! New user - 2 basic Quartz64 questions oldschool 2 5,410 12-14-2023, 12:06 AM
Last Post: oldschool
  New RockPro64 Power Up Problem enorbet2 7 14,293 10-28-2023, 12:08 PM
Last Post: dkebler
  New User use PineBookPro default OS Manjaro clessard 0 3,209 07-02-2022, 09:01 AM
Last Post: clessard
  Can I use the pinetime as a blind user pranav 1 4,525 06-22-2022, 01:07 PM
Last Post: zer0sig
  First time user experiencing weird keyboard issues kendew 5 11,404 06-19-2021, 08:14 AM
Last Post: rotwang
  Pinecil power Erincka 0 3,593 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 3,679 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 4,576 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 25,032 03-12-2021, 07:08 PM
Last Post: cmicallef
  Changing locale on Pinebook Pro Perl6_user 5 12,429 09-16-2020, 05:13 PM
Last Post: guava
