No USB Power (ROCK64+ARMBIAN 5.7)
Question
Armbianmonitor:
http://ix.io/1DAn
Hello, can someone help me with my problem.
I have a ROCK64 with 4GB of RAM and an ARMBIAN 5.75 stable Ubuntu 18.04.2 LTS 4.4.174-rockchip64, installed.
My issue come with usb ports, from the three USB of the this device only works two: one 2.0 and 3.0. And when i have a disk connected towards usb 3.0 i have issues with port usb 2.0, it doesn't work well and I end up disconnecting the USB 3.0 to can work with my device connected towards USB 2.0 so I assume that the current power on the USB port is having issues or it's not working well.
Anybody an idea?
thanks!
Typical power supply issues. You can either try a different power supply to rule this in or out or use a meter to measure the current draw on the power supply when all USB ports are in use.
(03-15-2019, 07:36 AM)Rocklobster Wrote: Typical power supply issues. You can either try a different power supply to rule this in or out or use a meter to measure the current draw on the power supply when all USB ports are in use.
any other options or ideas?
is there any way to check current power of each usb from OS?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 11 16,367 12-06-2025, 01:32 PM
  Xen hypervisor on Rock64 tumbleweed 6 10,191 11-03-2025, 09:25 AM
Last Post: darkfader
  Rock64 - not booting after Armbian update helpmerock 6 4,042 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,507 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,638 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,761 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 73,393 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 102,075 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 4,899 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,747 12-27-2023, 10:34 AM
Last Post: dstallmo
