ayufan 0.7.12 pre-release images (help testing)
New pre-release images from ayufan are now available. Help testing, submit prs and fixes. Feedback welcome.
(02-25-2019, 02:54 PM)Luke Wrote: New pre-release images from ayufan are now available. Help testing, submit prs and fixes. Feedback welcome.
Very basic question:
I am unable to update to pre-release
I am doing something wrong in ayufan-rock64.list
I modified it from
 deb http://deb.ayufan.eu/orgs/ayufan-rock64/releases /
# uncomment to use pre-release kernels and compatibility packages
# deb http://deb.ayufan.eu/orgs/ayufan-rock64/pre-releases /
to
# deb http://deb.ayufan.eu/orgs/ayufan-rock64/releases /
but this not working!
root@rockpro64:~# sudo apt-get install linux-rockpro64 -y
Reading package lists... Done
Building dependency tree
Reading state information... Done
linux-rockpro64 is already the newest version (0.7.9).
0 upgraded, 0 newly installed, 0 to remove and 61 not upgraded.
Luke, it would be really helpful if the lxde build or any other desktop being offered or any min build for that matter would have wifi configuration standard. reason i say this is i currently do not have ethernet , all my access is through a cellphone hotspot. everybuild i d/l for rock64 [btw, i know this is pro, but that is really beside the point] to test goes like this, 1.download 2.burn image 3. boot 4. look for wifi set up 5. no wifi setup 6. test over. you guys must think everyone has ethernet. that is not the case. thank you for any consideration.
(03-07-2019, 08:59 AM)dkryder Wrote: Luke, it would be really helpful if the lxde build or any other desktop being offered or any min build for that matter would have  wifi configuration standard. reason i say this is i currently do not have ethernet , all my access is through a cellphone hotspot. everybuild i d/l for rock64 [btw, i know this is pro, but that is really beside the point] to test goes like this,  1.download  2.burn image  3. boot  4. look for wifi set up  5. no wifi setup  6. test over. you guys must think everyone has ethernet. that is not the case. thank you for any consideration.
Working towards that.
I modified it from
to
>>> Maybe silly Q BUT did you do all 3 of these commands after uncommenting package list?
sudo apt-get update -y
sudo apt-get install linux-rock64 -y
Hi all,
I am using the ayufan 0.7.14 debian stretch with ayufan's 5.0.0-1101 mainline kernel. I would like to enable the zswap but I can not find the zswap module. Anyone using this or knows how to enable it?
thx,
(03-15-2019, 04:27 AM)huey Wrote: Hi all,
thx,
CONFIG_ZSWAP is not listed in https://github.com/ayufan-rock64/linux-m..._defconfig so double check with
    zcat /proc/config.gz | grep CONFIG_ZSWAP
and assuming no output you should compile the option in, test, then make a pull request.
Hi Ayufan
First like to thank you for all the hard work you are putting into these iamges.
I have just been running 0.7.14 version.
All is looking good. I have the WiFi working now but it looks like Bluetooth is stilla problem. Bluetoothctl reports that it cannot find the device.
Thought I would let you know.
Mike
Are these images for SD card or EMMC? Just asking. Oh by the way Ayufan thanks for all the hard work I appreciate it.
(03-19-2019, 01:57 AM)battlenut Wrote: Are these images for SD card or EMMC? Just asking. Oh by the way Ayufan thanks for all the hard work I appreciate it.
They should work on both SD and eMMC
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,140 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 9,479 04-23-2023, 01:32 PM
Last Post: diederik
  Armbian images available Luke 60 146,901 08-04-2022, 06:56 AM
Last Post: Rocklobster
  Armbian 22.02 Release Announcement TRS-80 0 3,007 02-28-2022, 05:08 PM
Last Post: TRS-80
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 3,290 07-24-2021, 09:46 PM
Last Post: Mentaluproar
Big Grin Feature Complete Debian Desktop Release Mrfixit2001 158 296,481 05-29-2021, 04:05 AM
Last Post: twilite
  ayufan kernel update unbootable TheHunter 2 5,942 03-12-2021, 05:17 PM
Last Post: LMM
Question Ayufan RockPro64 updates? hemertje 3 10,077 10-22-2020, 01:16 PM
Last Post: dukla2000
  Kernel Update from 4.4 (Ayufan) on Ubuntu 20.04 db579 3 9,704 10-22-2020, 01:12 PM
  Official Debian release won't boot!?! Faradn 4 11,074 07-06-2020, 09:29 AM
Last Post: Bullet64
