Manjaro ARM for Pinebook
#21
(12-14-2018, 07:07 AM)Luke Wrote: Official release of Manjaro 18.12 for Pinebook. Works on both regular and 1080p Pinebooks.
erchache2000 please edit your first post so that it points to the official releases rather than the preview images, thank you!
Did it! ;P
#22
I tried Manjaro with LXDE, and noticed that speed graphics is worse than on KDE Neon. Windows move slowly, and a mouse cursor flickers. But 3d (according to glxgears) is better (as I understand there is only software 3d in Neon). Is it possible to improve 2d graphics?
And what about suspend. Is work in progress?
#23
(01-09-2019, 06:42 PM)tahf Wrote: I tried Manjaro with LXDE, and noticed that speed graphics is worse than on KDE Neon. Windows move slowly, and a mouse cursor flickers. But 3d (according to glxgears) is better (as I understand there is only software 3d in Neon). Is it possible to improve 2d graphics?
Upgrade your system
$sudo pacman-mirrors -g && sudo pacman -Syyu
and/or try other Window Manager.
I’m using XFCE4 and goes well for my normal use. For 3D perhaps needs a kernel with sunxi drm drivers. But I think that is a DIY solution... ;(
Go to manjaro arm forum and ask for it.
#24
Updated Manjaro KDE (Pinebook1080P) 19.02 on Wiki and Pine64 Installer
Updated Manjaro  LXQT (Pinebook1080P) 19.02 on Wiki and Pine64 Installer
Updated Manjaro KDE (Pinebook) 19.02 on Wiki and Pine64 Installer
Updated Manjaro  LXQT (Pinebook) 19.02 on Wiki and Pine64 Installer
#25
Hi, I'm wondering if someone could help me?
I'm having an issue writing the img to an SD card. I downloaded the img.xz and unzipped it no problem. I then have tried using "dd" command in CLI to write the img to the micro SD card. As far as I know, the writing process is happening (takes 2-5mins) and there are no errors that show up after the write is done. (I ran umount command to unmount the card before writing).
But then when I view the SD card in Gparted, it shows as "unknown" partition/volume and my pinebook will not boot to it (it still just boots into KDE Neon as usual).
Any reason why this might be happening? Am I doing something wrong? It's a brand new 16GB mSD card and it showed up fine in dolphin when first inserted into the pinebook.
Thanks in advance for any assistance.
**EDIT** I might have figured out what's happening. I was writing to /dev/mmcblk1p1 instead of /dev/mmcblk1
Fingers crossed it works this time...
#26
Information
New 19.3 Manjaro KDE and LXQT images for the Pinebook are now available for download here.
The images feature a range or improvements - including general performance.
[Image: xDMIo5E.png]
#27
I installed 19.3 manjaro kde in pinebook.
but I have a problem, 'hdmi output' only works in unify mode.
I want to switch output mode, as in unify mode the screen resolution is not correctly worked.
Menu lists show up when press 'command key + p'
But the mode is not changed. nothing happened
How can I change the mode to external only?
#28
Is there any measurable performance or support differences between Manjaro KDE and Neon KDE on the Pinebook, or is it just largely base system and visual differences?
[ PHP Developer | Pinebook 1G | About me ]
#29
A new i3 WM image is now available from Manjaro and boy its lightweight and good!
Thread and related downloads can be found here
#30
(03-24-2019, 12:10 AM)pineuseran Wrote: I installed 19.3 manjaro kde in pinebook.
In manjaro 19.2 kde, hdmi output works fine but  sound not works. When system upgrade, upgrade progresses but error massage continues.
In manjaro 19.3 kde, sound works fine but hdmi output only works in unify mode. After system upgrade, wifi network are disabled.
In manjaro i3, sound and system upgrade work fine but hdmi output only works in unify mode.
I installed it to sd card in pinebook 14. I'm posting in i3.
  DietPi OS for Pinebook MichaIng 5 17,232 07-28-2026, 08:02 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 14,636 05-18-2026, 02:11 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 104,513 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,949 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,504 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 16,831 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,462 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,778 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,480 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,531 01-20-2021, 11:18 AM
