11-21-2018, 01:08 PM
(10-28-2018, 07:02 AM)petec Wrote: Any news on the Rock64 with RTC?
Please check this link:
https://forum.armbian.com/topic/8856-sol...k64-board/
ROCK64 RTC
(10-28-2018, 07:02 AM)petec Wrote: Any news on the Rock64 with RTC? Please check this link: https://forum.armbian.com/topic/8856-sol...k64-board/
Thank you turkerali.
Not looking to modify the Rock64 for an RTC / battery as the RTC / Battery. The RTC was promised with inception of the first Rock64 (next build and release over a year ago). I have done similiar here to micro routers using OpenWRT, RPi's and my Intel touchscreen tablets (very difficult to do). Used an el cheapo micro router which is doing python, mosquitto, firewall stuff, RTC/battery mods, GPIO adds, et al. My time base here if via a GPS / PPS connected to PFSense many years ago. Actually relating to my personal automation went to an NTP server in the 1990's while concurrently using the internet. Here very time sensitive. Just noticed that I did not get any response relating to my last RTC update of hardware request? It was promised over a year ago.
Pete
Auto mator
01-29-2019, 08:59 AM
Im seriously disappointed that the Rock64 does not have a RTC ...
when no accurate time is set, the web browsers do not allow access .. and setting time via internet is hard to force ... Pecet :: Did you have a reasonably priced via a GPS / PPS time solution?
01-29-2019, 03:29 PM
01-30-2019, 09:50 AM
ntpd is not used any more ... i thought, timedatectl is used now
I get a bash error stating that ntpd : command not found
01-30-2019, 04:22 PM
(01-30-2019, 09:50 AM)KC7NOA Wrote: ntpd is not used any more ... i thought, timedatectl is used now I'm just used to using ntpd and fake-hwclock on headless systems. v3 of the rock64 has RTC Quote:I get a bash error stating that ntpd : command not found If other options aren't working for you, you can do the following: sudo apt install ntp fake-hwclock
01-31-2019, 12:51 PM
(01-30-2019, 04:22 PM)evilbunny Wrote:(01-30-2019, 09:50 AM)KC7NOA Wrote: ntpd is not used any more ... i thought, timedatectl is used now I have used sudo apt install ntp fake-hwclock in the past, couldn't remember what it was from the past either .... Though a RTC would be great .. Or PPS from a Sat .. but that seems like a pain anymore ... This is what i meant for the other error .. but i think it is because of trying to overwrite '/usr/lib/aarch64-linux-gnu/libEGL.so', which is also in package libmali-rk-utgard-450-r7p0:arm64 1.6-1ayufan10 Errors were encountered while processing: /var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.2_arm64.deb E: Sub-process /usr/bin/dpkg returned an error code (1) rock64@rock64:~/Downloads/sdrangel/build$
01-31-2019, 06:54 PM
(01-31-2019, 12:51 PM)KC7NOA Wrote: trying to overwrite '/usr/lib/aarch64-linux-gnu/libEGL.so', which is also in package libmali-rk-utgard-450-r7p0:arm64 1.6-1ayufan10 You should be able to use dpkg with --force to make the installer overwrite the file Code: dpkg --force-help
02-01-2019, 02:23 PM
(01-31-2019, 06:54 PM)evilbunny Wrote:That does not mean much to me .. the help contents is not helpful when you dont know what to do with the contents(01-31-2019, 12:51 PM)KC7NOA Wrote: trying to overwrite '/usr/lib/aarch64-linux-gnu/libEGL.so', which is also in package libmali-rk-utgard-450-r7p0:arm64 1.6-1ayufan10
02-01-2019, 04:03 PM
(02-01-2019, 02:23 PM)KC7NOA Wrote:(01-31-2019, 06:54 PM)evilbunny Wrote:That does not mean much to me .. the help contents is not helpful when you dont know what to do with the contents(01-31-2019, 12:51 PM)KC7NOA Wrote: trying to overwrite '/usr/lib/aarch64-linux-gnu/libEGL.so', which is also in package libmali-rk-utgard-450-r7p0:arm64 1.6-1ayufan10 You could try the following, but I haven't tested, which is why I posted the help screen: sudo dpkg --force-overwrite -i /var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.2_arm64.deb |
| Rock64 No Audio @ Debian 12 | dmitrymyadzelets | 2 | 4,589 |
04-08-2024, 06:47 AM Last Post: dmitrymyadzelets |
| OpenWRT on the Rock64 | CanadianBacon | 14 | 20,973 |
04-03-2024, 08:48 AM Last Post: helpmerock |
| Rock64 bricked | shawwwn | 7 | 13,020 |
03-17-2024, 12:22 PM Last Post: dmitrymyadzelets |
| Rock64 won't boot | luminosity7 | 10 | 13,984 |
03-16-2024, 08:33 AM Last Post: dmitrymyadzelets |
| Rock64 doesn't boot | dstallmo | 1 | 3,563 |
03-16-2024, 08:29 AM Last Post: dmitrymyadzelets |
| How well does Rock64 deal with HDR and Atmos on Kodi? | drvlikhell | 3 | 7,381 |
04-29-2023, 04:24 AM Last Post: newestssd |
| Rock64 board not working, no HDMI no Ethernet. | EDited | 3 | 8,226 |
01-17-2023, 02:31 PM Last Post: Flagtrax |
| ROCK64 v3 can it boot from USB? | Tsagualsa | 4 | 7,660 |
11-29-2022, 11:31 AM Last Post: Macgyver |
| rock64 v3 spiflash | Macgyver | 0 | 3,509 |
11-28-2022, 02:18 PM Last Post: Macgyver |
| my rock64 dosen't work | rookie_267 | 0 | 3,490 |
10-07-2022, 07:50 PM Last Post: rookie_267 |
