03-30-2016, 05:30 AM
Hi, my board arrived today and I now realize I failed to order the WiFi/BT Module. Is it possible to get ahold of one of these separately ? How ?
Thanks !
Thanks !
Getting the WiFi/BT Module
Thanks !
03-30-2016, 05:51 AM
03-30-2016, 09:19 AM
(03-30-2016, 05:51 AM)peterz Wrote:(03-30-2016, 05:30 AM)patmolloy Wrote: Hi, my board arrived today and I now realize I failed to order the WiFi/BT Module. Is it possible to get ahold of one of these separately ? How ? Ah, Ok
03-30-2016, 01:47 PM
(03-30-2016, 09:19 AM)patmolloy Wrote:There should be possible to use USB WIFI adapter and/or USB Bluetooth adapter.(03-30-2016, 05:51 AM)peterz Wrote:(03-30-2016, 05:30 AM)patmolloy Wrote: Hi, my board arrived today and I now realize I failed to order the WiFi/BT Module. Is it possible to get ahold of one of these separately ? How ? But drivers might be an issue at the moment (@longsleep if you see this correct me if I'm wrong). You could do it by "attempt/mistake approach" and try several adapters but that might be more costly and lengthy than buying WiFi/BT module from online shop in May.
03-30-2016, 03:19 PM
I tried the WiFi/BT module which is certified with Pi2 - it didnt work with this board unfortunately. If you go the Linux route, you may get more drivers - Android is an issue that way!
[split] Better WiFi/BT module? | moriel5 | 3 | 5,883 |
05-18-2022, 01:55 PM Last Post: moriel5 |
WIFI/BT Power Supply / VBAT-EXT | xalius | 3 | 5,395 |
08-12-2021, 06:41 AM Last Post: Luke490 |
Better WiFi/BT module? | fonix232 | 20 | 28,355 |
08-11-2021, 09:27 AM Last Post: Jean-Marc LACROIX |
Wifi / Bluetooth Board Update | S265 | 2 | 4,644 |
07-30-2020, 04:53 PM Last Post: S265 |
Create a WiFi hotspot on Debian 8 | JulianM | 6 | 28,393 |
03-10-2019, 01:02 AM Last Post: waqasnasir |
Schematics of Wifi/BT module | gamelaster | 7 | 10,985 |
09-11-2018, 02:02 PM Last Post: gamelaster |
Wireless Module Driver Source code | mido2018 | 0 | 2,251 |
08-08-2018, 04:26 PM Last Post: mido2018 |
Installing another WiFi module on one of the buses | mido2018 | 1 | 3,996 |
07-22-2018, 07:15 AM Last Post: tllim |
Unable to activate wifi on Linux | smouton | 10 | 17,446 |
02-21-2018, 09:56 PM Last Post: dkebler |
Pine64 doesn't recognize Wifi/BT Module | clobeca | 3 | 6,746 |
07-13-2017, 08:58 PM Last Post: MarkHaysHarris777 |
