Rock64 With Android TV 7.1 Won't boot using 3.5mm power barrel
I can only get the Rock64 to boot with a USB A-2-A cable. If I plug in a cable to the barrel it won't boot.
I am using this for power: https://www.tronsmart.com/products/w2ptu...ll-charger
With a cable like this: https://www.amazon.ca/Duttek-3-5x1-35-Ch...ower&psc=1
[url=https://www.amazon.ca/Duttek-3-5x1-35-Charging-Electronics-Converter/dp/B07DL1DV7T/ref=sr_1_1_sspa?ie=UTF8&qid=1542236800&sr=8-1-spons&keywords=usb-a+3.5mm+power&psc=1][/url]
Would the only reason be that the USB-A port on this charger is not providing 5V-3A? If I use this adapter should I get a USB-C to USB-A cable to make this adapter work?
(11-14-2018, 05:09 PM)Eric82 Wrote: I can only get the Rock64 to boot with a USB A-2-A cable. If I plug in a cable to the barrel it won't boot.
Some USB charging power source only supply 2A current to the device that it recognized and by default just supply 500mA. We always advise user not using the USB charger to power Single Board Computer.
  rock64-android10-tv patchset for Firely AlexS 1 669 09-08-2026, 10:49 PM
  Android Images (ROCK64) pineadmin 77 245,828 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,408 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,691 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,857 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,855 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,562 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,731 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,385 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,664 09-18-2020, 08:12 PM
Last Post: BowerR64
