Pinebook won't charge
I have been away from home for a long time and haven't used my Pinebook. I have read that an amber light would indicate the battery is charging. This light doesn't turn on, even after inserting the power cable multiple times (>10).
I have been searching the internet for a replacement battery, but the model number can not be found. The voltage 4.35V is also an unusual number. It seems that voltages are always a multiple of 3.7V.
Is there anyway I can reanimate my Pinebook? Or have I been robbed of my money with a now useless product. Angry
Have you tried to charge it for some hours? I have had this, too, but after ~2 hours of charging it worked again (After ~1h it showed the battery logo for some seconds when pressing the power button, but it did not start).
(10-19-2018, 01:51 AM)Juwie Wrote: Have you tried to charge it for some hours? I have had this, too, but after ~2 hours of charging it worked again (After ~1h it showed the battery logo for some seconds when pressing the power button, but it did not start).
I have opened the Pinebook and unplugged the battery (read that solution somewhere), plugged it back in.
When I inserted the power adaptor the battery indicator with a lightning flash appeared shortly. I left the Pinebook like that for a whole night and this morning it started up again with a fully charged battery. With the adaptor unplugged it had roughly 6 hours of battery charge. I can't remember if that was the same as when I got the Pinebook. I am happy again  Smile and will make sure not to drain the battery to 0%.
I will just gently point out that reading this post would offered up the answer...
Mark the thread as solved for future users.
(10-19-2018, 05:46 AM)Luke Wrote: I will just gently point out that reading this post would offered up the answer...
Problem solved, however I didn't have the power plug connected while unplugging the battery from the Pinebook.
  Running Pinebook (non-Pro) without battery? guidol 0 752 11-09-2025, 04:19 AM
Last Post: guidol
  Anyone selling a Pinebook ams 2 10,760 09-08-2025, 09:26 AM
Last Post: ams
  Giving away a Pinebook Pro for free (with a broken hinge) tuxifan 4 5,279 09-01-2025, 12:24 AM
Last Post: alchemist
  pinebook 1080p power/barrel connector/cable cel 0 2,186 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 3,614 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 3,513 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 4,841 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 7,290 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 5,743 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 6,772 01-13-2021, 11:03 AM
Last Post: barray
