/dev/spidev0,0 on the Rock64 - Does anyone know how to enable it?
Please check connection again. I see GND connected to pin 18 and not pin 20 and other errors.
Do you have 4.2" or 4.2"b/c ?
I modified 4.2" (monochrome) python demo code. Do not press ctrl-c main.py should be done after 35 seconds.
.tar   eink42_sample.tar (Size: 120 KB / Downloads: 720)
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
Star
It freaking works!!! That is awesome. You are awesome :-)
Normally I don't do work on weekends, but this is so great :-))
I might/will have a couple of context-questions to grasp a few things and with your permission/help I'll write a doc how to use the eInk Displays in general in the following weeks.
Thanks again :-)
(09-09-2018, 05:26 AM)Kappuchino Wrote: It freaking works!!! That is awesome. You are awesome :-)
Thanks again :-)
Looking forward on your doc on eInk display.
Thanks again :-)
K
Did you get to writing up a doc on eInk Displays and the Rock64 ??
Would be great
Thanks to @mcerveny's posts in this thread, I was able to get a waveshare 2.7" e-paper hat working on my Rock64 v2, Armbian.
However, as mentioned above, due to the Rock64 pin out, it does not seem readily possible to utilize the display as a 'hat', as intended... which is a shame.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,878 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,366 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,000 07-22-2026, 01:47 PM
Last Post: MichaIng
  A/V output enable 8lall0 0 1,393 03-24-2026, 04:45 PM
Last Post: 8lall0
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,205 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,789 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,798 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,099 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,297 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,161 09-20-2024, 11:18 AM
Last Post: AwU2HBg
