My Rock64 no power or light issue
Hey everyone just got my board in today had my sd card ready with android Oreo on it. Plugged everything up to (ie: HDMI,ethernet cable and remote dongle) plugged in the power supply I bought from them along with my board ........and nothing no lights no power nothing. This was for the initial start up need some help Pine family thanks
I assume you tried powering it up without an SD card inserted and got the same result. Sounds like a bad power supply or a bad power connector on the board. Hard to tell. Do you have a meter to test output on power supply and input on the board.
If you had a power supply from an old IP webcam which has the same barrel connector you could try using it to rule out a DOA board. Those IP webcam power supplies are usually 2amp so it would at least boot up the Rock64 if it's working.
Alternatively you could just return the lot to the supplier
The green LED of ROCK64 is directly connected to the power supply and can not be controlled by software.
Therefore, if the green LED does not light up, it means that an appropriate voltage is not supplied from the power-supply.
1. The power supply itself is broken.
2. The board & the equipment connected to it required excessive current, so the power supply was protected
Disconnect all connected peripheral devices and try supplying power
Still if the green LED does not light up the power-supply or ROCK64 board is broken.
He plugged power into the audio jack. Solved.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,431 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 25,989 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 15,510 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 17,030 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,222 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,032 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,134 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,366 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,433 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 4,532 10-07-2022, 07:50 PM
Last Post: rookie_267
