yes, it was necessary to specify that the "sdcard" is a "micro sd card".
thank you.
it's nice to hear that the system is working on your board.
thank you.
slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
thank you. it's nice to hear that the system is working on your board.
05-21-2018, 01:43 AM
(05-21-2018, 01:43 AM)pineadmin Wrote: Added Slackware Aarch64 Miniroot (ROCK64) 20180508 on Wiki and PINE64 Installer. many thanks, the only thing, since this port (aarch64) is not an official trademark of Slackware is not correctly used. The project for rebuilding Slackware under the aarch64 architecture was re-named in Slarm64, but this does not apply to assemblies on the architecture arm
update kernel and packages
the video is played through mpv, 1080p cpu load is 89% slack-current-aarch64-miniroot_22May18-4.4.132-rock64-build-20180526.img.tar.xz slack-current-aarch64-miniroot_22May18-4.4.132-rock64-build-20180526.img.tar.xz.md5 slack-current-aarch64-xfce_22May18-4.4.132-rock64-build-20180526.img.tar.xz slack-current-aarch64-xfce_22May18-4.4.132-rock64-build-20180526.img.tar.xz.md5
graphics are displayed using mali blob gbm slack-current-aarch64-miniroot_22May18-4.4.133-rock64-build-20180701.img.tar.xz slack-current-aarch64-miniroot_22May18-4.4.133-rock64-build-20180701.img.tar.xz.md5 slack-current-aarch64-xfce_22May18-4.4.133-rock64-build-20180701.img.tar.xz slack-current-aarch64-xfce_22May18-4.4.133-rock64-build-20180701.img.tar.xz.md5
R64 4GB wont boot with any Slackware image. Here is a loglevel=8 boot message capture: http://termbin.com/9stym
I tried to blacklist sdio/bcmdhd with a kernel parameter but either my syntax is wrong or the parameters are ignored because they do not appear in the boot log and the error remains. This is what i tried to add to uEnv.txt: Code: extraargs=rd.blacklist=bcmdhd module_blacklist=bcmdhd
07-02-2018, 09:36 AM
(07-01-2018, 11:06 PM)ansic Wrote: R64 4GB wont boot with any Slackware image. Here is a loglevel=8 boot message capture: http://termbin.com/9stym the rtl8188eu, bcmdhd modules are configured as part of the kernel. if you do not like the output at startup, you can set the verbosity parameter to 1
rebuilt the kernel with support for usb realtek and mediatek in the form of modules
download http://dl.fail.pp.ua/slackware/pkg/aarch...-3mara.txz http://dl.fail.pp.ua/slackware/pkg/aarch...-3mara.txz http://dl.fail.pp.ua/slackware/pkg/aarch...-3mara.txz http://dl.fail.pp.ua/slackware/pkg/aarch...-3mara.txz Code: upgradepkg kernel*.txzdmesg
update kernel 4.4.138
kernel-firmware-rk3328-4.4.138-aarch64-1mara.txz kernel-headers-rk3328-4.4.138-aarch64-1mara.txz kernel-modules-rk3328-4.4.138-aarch64-1mara.txz kernel-rk3328-4.4.138-aarch64-1mara.txz Code: upgradepkg kernel*.txz
07-22-2018, 12:54 PM
| irradium (based on crux linux) Rock64 riscv64, aarch64 | mara | 11 | 16,158 |
12-06-2025, 01:32 PM Last Post: mara |
| Xen hypervisor on Rock64 | tumbleweed | 6 | 10,045 |
11-03-2025, 09:25 AM Last Post: darkfader |
| Rock64 - not booting after Armbian update | helpmerock | 6 | 3,863 |
03-27-2025, 08:26 AM Last Post: wdt |
| can rock64 4gb ram run entirely on free software? | heocb | 1 | 2,440 |
01-07-2025, 05:47 AM Last Post: KC9UDX |
| Upgrading ancient Rock64 | timxjr1300 | 1 | 2,570 |
11-26-2024, 09:47 AM Last Post: dmitrymyadzelets |
| arch rock64 does not boot | nemnob | 1 | 3,646 |
09-20-2024, 11:18 AM Last Post: AwU2HBg |
| DietPi OS for ROCK64 | MichaIng | 42 | 71,210 |
09-01-2024, 06:43 AM Last Post: RaymondDay |
First Lakka image for Rock64! | Luke | 47 | 101,169 |
09-01-2024, 06:05 AM Last Post: RaymondDay |
| Rock64 v2 - did not work song / audio | sqw200zu | 2 | 4,652 |
03-14-2024, 03:09 AM Last Post: dmitrymyadzelets |
| Rock64 won't boot | dstallmo | 0 | 2,697 |
12-27-2023, 10:34 AM Last Post: dstallmo |
