[Archived] ANNOUNCING RECALBOX FOR THE ROCK64 - ALPHA RELEASE
#31
Xbox One (2 pads old/original - no 3.5mm jack) - pad detected - doesn't recognise key strokes - unable to configure
Xbox One Elite (2 pads) - pad detected - doesn't recognise key strokes - unable to configure
PS4 pad over USB (2 pads) - pad not detected
PS4 pad over BlueTooth - pad paired and detected - doesn't recognise key strokes - unable to configure
PS3 pad over USB (2 pads) - pad not detected
Keyboard (multiple) - detected as default controller - configure and play all fine
Everything I've tested so far worked great
...except N64
Small and with textures messed up.
...but in full speed.
Smash Bros.[Image: 808f8bd384ddc9839de3d7bf28e58420.jpg]
Scrapper works great!!
Amstrad demo game is either out is resolution or hanged Rock.
As for alpha, I'm impressed.
Rock64 + recallbox has better first impression than Raspberry 3 + Retropie.
Wysłane z mojego Redmi Note 4 przy użyciu Tapatalka
#32
(05-01-2018, 02:58 PM)S3phi40T Wrote: Xbox One (2 pads old/original - no 3.5mm jack) - pad detected - doesn't recognise key strokes - unable to configure
...except N64
Thank you for the testing and feedback!!!
A few tips - in the recalbox menu under advanced you can select what default emulator and core you want to use for each system. And under each rom's meta data you can even specify a different emulator and core just for that rom. Not all roms will perform the same on the same core, that's why why I included as many as possible for n64.
For the gamepads, see if you get different results if you plug them in before you boot. I think I remember reading that sometimes recalbox doesn't pick them up right if you plug them in while it's already running.
#33
Also just FYI, I just checked and libnfs is already on the image. Smile
#34
...except N64
Please try the following:
nano /recalbox/share/system/configs/mupen64/gles2n64rom.conf
and edit out the forced resolutions of the games you're trying to play.
[edit] for reference, could you also try Mariokart64 and see if that plays full screen? (it should)
[edit 2] also could you try editing
nano /recalbox/share/system/configs/mupen64/gles2n64.conf
and changing all settings - including Framebuffer and VI - to 1080p
Dzięki.
#35
Eventually I got a 64GB flashcard and I flashed Recalbox, it started however the booting is pretty messy with a lot of issue about ext2/3 partitions... I figured out that it was normal because the alpha state. I confirm that my gamepad works out of the box with Recalbox for R64, thanks!
#36
Danielsan, yep thats normal (for now) - will be dealt with eventually. By Beta no doubt.
S3phi40T, I can confirm the issue with Xbox 1 and PS4 BT gamepads.
#37
Dualshock 4 works with after you configure it manually with bluetoothctl
3D PS1 games aren't going too well. Do you anticipate being able to improve performance with future updates, or is that just the hardware's limit?
It's possible it's throttling because I don't have a heatsink on. I bought one and will install it to see if that helps.
#38
Hi, I can't see the N64 emulator neither I find a way to download the core...
Is there anything else I have to do to enable the N64?
PSX is silky smooth for me. [edit] Even with the enhanced resolution option ticked. Are you using any shaders ?
Could you please enable FPS counter and report the FPS in Tekken 3 please? I literally haven't had a single game dip below its intended framerate, so something is not right.
As for N64 you need games in .z64 format (not .zip) - I suspect thats why you're not 'seeing' the emulator.
Logs please! Otherwise its a guessing game...
#40
Where are stored the logs? I can enter through ssh and providing them.
Unfortunately my PSX emulation is pretty awful, very poor performance, and after copied the bios files the video doesn't work properly I get a black screen while the music run from the speaker.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 22,006 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,472 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,370 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,236 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,865 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,869 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,127 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,340 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,193 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 119,649 09-01-2024, 06:05 AM
Last Post: RaymondDay
