slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#21
(04-29-2018, 12:06 AM)mara Wrote:
(04-28-2018, 05:03 PM)valarauca Wrote: Hello could you host a torrent?
Your webserver is incredibly slow (and spotty) to download from. I'll happily assist in seeding.
ok, http://dl.fail.pp.ua/slackware/images/ro...cy.torrent
HTTP 403 ?
Can confirm, forbidden here in Oz also Wink
HTTP 403 ?
fix
(04-29-2018, 03:21 AM)mara Wrote: fix
Confirmed. I have a rtorrent session listening and waiting to seed in a VPS over in the Netherlands... although it's not doing much atm...
fix connection
(04-29-2018, 06:50 AM)mara Wrote: fix connection
The slack-Xfce 4.4.126 image works on micro SD at home without modification
On the other hand it crashes after a few minutes
update images:
slack-current-aarch64-miniroot_08May18-4.4.126-rock64-build-20180508.img.tar.xz
slack-current-aarch64-xfce_08May18-4.4.126-rock64-build-20180508.img.tar.xz
(05-08-2018, 02:39 PM)mara Wrote: update images:
Hello
Are people managed to run the slack... Xfce image?
I no, even with a lot of attempts.... different micro SD cards and a lot of reboot.
Yet I think it had to be tested before!!! I do not know where the problem comes from?
Thank you for your answers
Hello
hi
I tested the download from sdcard
http://p.fail.pp.ua/Wz7ECz8O
Hello
hi
Hello Mara,
I deleted on the rock64 the Uboot-SPI-flash image I had installed before
and now the Slackware system starts up correctly on the USB micro and is stable at the moment.
Thank you for your previous Help
Hello
hi
Hello Mara,
Sorry
You had to understand on the "Micro SD card"
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 3,164 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 91,064 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,913 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,578 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,745 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,702 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,596 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,777 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,682 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 113,754 09-01-2024, 06:05 AM
Last Post: RaymondDay
