How do I prepare/put Android on an SD card using etcher
I've tried to install both, android-7.1-rock-64-rock64_atv-v0.3.13-r115-taw.img.gz and android-7.1-rock-64-rockbox_atv-v0.3.13-r115-taw.img.gz but when I try to flash the SD card it says that these images are not bootable. Why does it say this and what do I do to fix this? Likewise when I click "continue" and it flashes to the card, it won't boot. What do I do?
Sent from my SM-G930V using Tapatalk
(04-17-2018, 11:24 PM)cdotsubo3000 Wrote: I've tried to install both, android-7.1-rock-64-rock64_atv-v0.3.13-r115-taw.img.gz and android-7.1-rock-64-rockbox_atv-v0.3.13-r115-taw.img.gz but when I try to flash the SD card it says that these images are not bootable. Why does it say this and what do I do to fix this? Likewise when I click "continue" and it flashes to the card, it won't boot. What do I do?
Unarchive the files (so that they are in .img format) and try again.
I've had the most consistent results using the below in bash shell
To usb mmc adapter:
gunzip -c android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img.gz | sudo dd of=/dev/sdX
To sdcard
gunzip -c android-7.1-rock-64-rock64_atv-v0.3.12-r115-raw.img.gz | sudo dd of=/dev/mmcblkX
same again in xz
to mmc
xzcat rock64_20171204_stock_android_7.1.2_rooted_emmc.img.xz | sudo dd of=/dev/sdX
or to sdcard
xzcat rock64_20171204_stock_android_7.1.2_rooted_sd2emmc.img.xz | sudo dd of=/dev/mmcblkX
I don't trust etcher, or anything dd'ing w/o telling me what it's doing
For me it's /dev/sdb and /dev/mmbblk0 btw, if in doubt plug or unplug the device and do
sudo dmesg
youl'll see it activated/deactivated and what it's name is
Prob work in MacOS, and should work in win10 with Windows Subsystem for Linux
I've only done myself in Debian.
Same as https://forum.pine64.org/showthread.php?tid=6034 - ignore the warning, it boots fine.
  Android Images (ROCK64) pineadmin 77 245,256 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,342 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,636 08-04-2021, 07:35 PM
Last Post: Rocklobster
  Android and SD Card gigagames 2 8,812 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,515 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,688 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,340 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,612 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,974 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 16,286 09-09-2020, 08:44 AM
Last Post: BowerR64
