slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
(04-12-2018, 09:35 PM)mara Wrote: good afternoon,
tell me:
  1.  what kind of image was used
  2. on which the image of a sdcard or emmc was recorded
  3. when downloading this board is installed emmc
1. unzip and then write to sdcard or emmc by PINE64 installer
      slack-current-aarch64-miniroot_06Mar18-4.4.115-rock64-build-20180311.img.7z
      slack-current-aarch64-xfce_06Mar18-4.4.115-rock64-build-20180311.img.7z
2. xfce ver. tested on emmc only and miniroot ver. tested on sdcard only
3. I use PINE64 installer. so....
I just tried on a Sony 1080p tv and got the same error message.
Is it ok to write your image to sdcard by Etcher(PINE64 installer)?
Thank you for your reply
this is not a mistake, the system is waiting for more.
after writing in the emmc image, you must mount /dev/mmcblk1p1
and make changes
add to the file /media/boot/uEnv.txt
     parameter rootdev=/dev/mmcblk1p1
     and fix it in the /media/etc/fstab file mmcblk0p1 on mmcblk1p1
after that, reboot before removing the sdcard
summing up what needs to be done:
mount /dev/mmcblk1p1 /media
echo "rootdev=/dev/mmcblk1p1" >> /media/boot/uEnv.txt
sed -i 's:mmcblk0p1:mmcblk1p1:' /media/etc/fstab
hello, I tried slack-current-aarch64-xfce_06Mar18-4.4.115-rock64-build-20180311.img.7 with only sdcard / emmc not have / by Etcher (PINE64 installer).
but it does not start.
how to run slack-current-aarch64-xfce_06Mar18-4.4.115-rock64-build-20180311.img. from sdcard? please help .
in this image you need to change the root disk
mount your sdcard
in the file /boot/uEnv.txt remove the line rootdev=/dev/mmcblk1p1
and also change the file /etc/fstab mmcblk1p1 on mmcblk0p1
update images:
slack-current-aarch64-miniroot_14Apr18-4.4.126-rock64-build-20180414.img.tar.xz
slack-current-aarch64-xfce_14Apr18-4.4.126-rock64-build-20180414.img.tar.xz
(04-14-2018, 12:04 PM)mara Wrote: update images:
ok. I tried to solve the problem in many ways but without a result. still does not boot from sd card. the same with these new images from the link you have set up. I leave this project for some time, maybe it will come back to it someday.
thanks for the help
Unzip and write to SDcard or eMMC by PINE64 installer
eMMC  - slack-current-aarch64-miniroot_14Apr18-4.4.126-rock64-build-20180414.img
SDcard - slack-current-aarch64-xfce_14Apr18-4.4.126-rock64-build-20180414.img
1. Tested on Rock64 4GB board
Power up Rock64 with eMMC and SDcard. It auto running until certain stage it show rebooting in 10sec message.
After reboot, the monitor unable get any display.
If reboot the board again get Fatal error or running until certain stage show rebooting in 10 sec
Please advice how to get the OS work on Rock64 4G board.
2. Tested on Rock64 2GB board
Power up Rock64 with eMMC and SDcard. It will auto running until show Login page.
What is login and password ?
note : both board have internet connection.
Please advice.
Thank you.
hi pineadmin,
all images are designed for sdcard,
if you write them on emmc you need to do the following manipulations:
      add to the file /boot/uEnv.txt
      and fix it in the /etc/fstab file mmcblk0p1 on mmcblk1p1
Quote:What is login and password ?
login: root
password: password
Hello could you host a torrent?
Your webserver is incredibly slow (and spotty) to download from. I'll happily assist in seeding.
(04-28-2018, 05:03 PM)valarauca Wrote: Hello could you host a torrent?
ok, http://dl.fail.pp.ua/slackware/images/ro...cy.torrent
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 11 16,192 12-06-2025, 01:32 PM
  Xen hypervisor on Rock64 tumbleweed 6 10,085 11-03-2025, 09:25 AM
Last Post: darkfader
  Rock64 - not booting after Armbian update helpmerock 6 3,884 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,450 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,582 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,676 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 71,774 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 101,484 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 4,702 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,704 12-27-2023, 10:34 AM
Last Post: dstallmo
