slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
support for slarm64 for rock64 development boards (aarch64 unofficial port slackware)
the system can be assembled as armhf and aarch64, assemblies are made under aarch64
links:
         site: fail.pp.ua
         forum: linuxquestions
         development: https://gitlab.com/sndwvs/images_build_kit
shortly about the slarm64, a simple non-overloaded system for everyday and not just use.
Thanks for posting.
playing video player 720p mpv, load on CPU 60-70%
[Image: attachment.php?attachmentid=27263&d=1521924560]
update kernel packages 4.4.120
Thanks, I will posted at wiki page on this week.
An installation guide would be great.
Is network boot planned?
howto:
1. download all http://dl.fail.pp.ua/slackware/images/rock64/legacy/
      slack-current-aarch64-miniroot_06Mar18-4.4.115-rock64-build-20180311.img.7z
      slack-current-aarch64-xfce_06Mar18-4.4.115-rock64-build-20180311.img.7z
2. flash /dev/mmcblk0 - уour memory card
      dd if=slack-current-aarch64-miniroot_06Mar18-4.4.115-rock64-build-20180311.img of=/dev/mmcblk0 bs=1M
3. for emmc firmware you need to boot from sdcard
      flash similarly by selecting /dev/mmcblk1
      add to the file /boot/uEnv.txt
      parameter rootdev=/dev/mmcblk1p1
      and fix it in the /etc/fstab file mmcblk0p1 on mmcblk1p1
Quote:Is network boot planned?
it's just a setup problem
update kernel packages 4.4.126
howto:
  1. download 4 packages *4.4.126*
  2. Code:
    upgradepkg *4.4.126*
Linux rock64 4.4.126 #1 SMP Wed Apr 11 21:16:32 EEST 2018 aarch64 GNU/Linux
Thank you.
I can only boot into a black screen. And after I forcefully power off/on my Rock64.
I got the following screen.
[Image: IbwJT3g.jpg]
Both miniroot and xfce version got the same result.
I guess it's related to my monitor's resolution (Dell U3014, 2560x1600@60). Any suggestion?
good afternoon,
tell me:
  1.  what kind of image was used
  2. on which the image of a sdcard or emmc was recorded
  3. when downloading this board is installed emmc
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,981 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,455 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,271 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,228 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,851 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,857 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,119 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,327 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,186 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 119,580 09-01-2024, 06:05 AM
Last Post: RaymondDay
