How install Qbittorrent on Debian?
I try but end-up with errors
Well it would help for a start if you describe what you did and what the errors are :-)
(03-14-2018, 08:36 AM)xalius Wrote: Well it would help for a start if you describe what you did and what the errors are :-)
I folow this tutorial https://www.tecmint.com/install-qbittorr...-in-linux/
the error:
rock64@rock64:~$ sudo apt-get install qbittorrent
[sudo] password for rock64:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 qbittorrent : Depends: libboost-system1.65.1 but it is not installable
               Depends: libqt5core5a (>= 5.8.0) but 5.7.1+dfsg-3+b1 is to be installed
               Depends: libqt5gui5 (>= 5.8.0) but 5.7.1+dfsg-3+b1 is to be installed
               Depends: libqt5network5 (>= 5.8.0) but 5.7.1+dfsg-3+b1 is to be installed
               Depends: libtorrent-rasterbar9 (>= 1.1.6+git20180215.01c41fadcf+patched-configure) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
rock64@rock64:~$
Anyone?
rock64@rock64:~$
It looks like you half upgraded packages, and then decided to set the apt repository to an older version.
The quick fix would be to re-flash an image. Otherwise you need to downgrade/upgrade to a later version.
Right now this image for rock64 board come with half upgraded packages:
http://wiki.pine64.org/index.php/ROCK64_...0171222.5D
  Debian installer on Pine A64+ but no hdmi mrwick 1 8,759 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 19,773 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,271 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 16,242 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 162,393 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,098 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Digital drawing tablet Huion - proper drivers install janeku 20 45,189 05-19-2019, 09:24 PM
Last Post: xinhua
  Script to build pure Debian images for Pine64+ amp 1 7,458 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 10,586 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 20,367 03-29-2019, 02:00 AM
Last Post: desai_amogh
