How to upgrade an existing Android eMMC load with new release
If I have an existing Rock64 eMMC Android load running how do I update to the newly released Android image without wiping out any changes I'd made to the load (apps installed, Google account signed in, settings tweaked, etc.)? Do I pull the "update" zip package, unpack it and then run the update.img using the Androidtool? If so, will that write over the my existing Android image on the eMMC module or just update it?  I've looked on the forum and github but haven't found much yet. By the way, the instructions for flashing the eMMC image worked flawlessly once I located a USB A to A cable. Nice work.
Yes, it should be possible to perform update. Just try to flash everything except misc.img partition.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
(08-28-2017, 07:03 AM)ayufan Wrote: Yes, it should be possible to perform update. Just try to flash everything except misc.img partition.
I use SD instead of eMMC, but i assume upgrading with OTG is the same. Has anyone tried it and the google account is still signed in?
I have Stock Rom, what is the difference to the community build? Can i also flash the community build over the Stock Rom without loosing the google signing in status?
Stock ROM is the OS build based on software SDK that provided by SoC vendor. The community build O comes from community developers. In general, the community build update frequency is higher than stock build. When you flash the community build over stock one or vice-versa, this like fresh installation and all current data will be loss. The good way is build the new OS on second SD card first and check out whether you likes the experience, and then decide.
Thank you for your answer :-)
  Android Images (ROCK64) pineadmin 77 217,891 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 10,625 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 9,809 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 9,264 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 7,209 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 6,139 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 5,451 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 9,333 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 4,295 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 7,324 09-18-2020, 07:58 PM
Last Post: BowerR64
