What is name of gpio hardware on a rock64?
The driver code checks for it, and will return a valid answer if its a bcm2709, bcm2835, bcm2836, or a bcm2837. Code is:
#define CPUINFO_BUFSIZE (16*1024) // Should be large enough for now
static platform_t check_platform(void)
FILE *fp;
char *buf;
size_t fsize;
platform_t rv = RPI_UNSUPPORTED;
if(!(buf = rtapi_kmalloc(CPUINFO_BUFSIZE, RTAPI_GFP_KERNEL))) {
rtapi_print_msg(RPSPI_ERR, "hm2_rpspi: No dynamic memory\n");
return RPI_UNSUPPORTED;
if(!(fp = fopen("/proc/cpuinfo", "r"))) {
rtapi_print_msg(RPSPI_ERR, "hm2_rpspi: Failed to open /proc/cpuinfo\n");
goto check_exit;
fsize = fread(buf, 1, CPUINFO_BUFSIZE - 1, fp);
fclose(fp);
// we have truncated cpuinfo return unsupported
if(!fsize || fsize == CPUINFO_BUFSIZE - 1) {
rtapi_print_msg(RPSPI_ERR, "hm2_rpspi: Platform detection memory buffer too small\n");
goto check_exit;
/* NUL terminate the buffer */
buf[fsize] = '\0';
if(strstr(buf, "BCM2708")) {
rv = RPI_1;
} else if(strstr(buf, "BCM2709")) {
rv = RPI_2; //for RPI 3 too
} else if(strstr(buf, "BCM2835")) { // starting with 4.8 kernels revision tag has board details
char *rev_val = strstr(buf, "Revision");
if(rev_val) {
char *rev_start = strstr(rev_val, ": ");
unsigned long rev = strtol(rev_start + 2, NULL, 16);
if(rev <= 0xffff)
rv = RPI_1; // pre pi2 revision scheme
else {
switch((rev & 0xf000) >> 12) {
case 0: //bcm2835
rv = RPI_1;
break;
case 1: //bcm2836
case 2: //bcm2837
rv = RPI_2; // peripheral base is same on pi2/3
break;
default:
break;
check_exit:
rtapi_kfree(buf);
return rv;
And all the c style indenting has been stripped, so how do I post code?  This sucks.
Thanks everybody.
Cheers, Gene83
gpio is a function of the soc [rockchip 3328]
Thank you very much.
Cheers, gene83
If you wish to verify that /proc/cpuinfo contains the board model, you better verify that first, because in some kernels, the name won't appear.
Some other way to do that is to verify /proc/device-tree/model ...
The only place I can find that is in /proc/device-tree/spi@ff190000 and that isn't explicit.
There are rockchip, and rk3328's scattered here and there but I've no clue how volatile they may be. But they I think hold the most promise, but it a whole new kilobyte of prelude code to get there, and I haven't hacked on c code in 25 years. Complicated by my wet ram turning 83 yo today.
Cheers & thanks, martinayotte
Gene83
On my board, doing "cat /proc/device-tree/model" returns "PINE64 ROCK64".
Whereas I get:Rockchip RK3328 Rock64
Without an eof or eol. And which would appear to be a valid ID.
Thanks. Not working on the code yet, morning here and I'm still a quart low on coffee. :-)
Cheers martinayotte, gene83
  rAudio for Rock64 V2 shinzuka 9 1,225 06-05-2026, 06:22 AM
Last Post: shinzuka
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 18,345 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 969 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,737 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,650 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,093 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,266 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,309 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 85,314 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 109,370 09-01-2024, 06:05 AM
