linux boot error
i cant boot with linux in rock64, i just format with pine installer, im using toshiba exceria 16gb, android works but linux dont   Huh
error output:
mmcblk1: error -84 sending status command, retrying
mmcblk1: error -84 sending status command, aborting
sd card tested with f3
(09-05-2017, 08:32 AM)jerson Wrote: i cant boot with linux in rock64, i just format with pine installer, im using toshiba exceria 16gb, android works but linux dont   Huh
You need to provide ayufan with the boot log captured with another computer connected to the Rock64 as described in the forum Hardware & Accessories category. The photos you sent aren't adequate. See:
"How to Setup Serial Console Cable Over the Rock64 SBC"
In minicom you will need to capture boot data into minicom.cap file.
Once in minicom, use Cntrl-A Z, then select L to:
        Turn Capture file on off. If turned on, all output sent to the screen will be captured in the file too.
In Ubuntu (Linux), the minicom.cap file should appear in your user home directory.
Send the minicom.cap file to ayufan.
Hope this helps.
+1, got same problem with all aufyan builds. SD Sony 16GB
Any news about this thread?
Also tried armbian and debian lxde image.
Rock64 started only with android imageSad
you might want to try the last release version rather than the latest build. also, there are a couple of other ways to write the image, there is pine installer, etcher, and if windows machine win32diskimage if you have ubuntu you can use the disks program, i think. so my advice is to format with sd card format program and then try an image program until you find one that works for your setup. there have been 2 programs i've used most of the time the past 17 months, i format the card with sd card format and write with win32diskimage when using my windows laptop and if on my ubuntu laptop i use etcher. the only utility i have ever had issues with is that piece of junk from allwiner, i can not remember the name, but if you have been around for a year or longer you may know the one i'm talking about and i have never used the pine installer.
Have you tested your SD card using H2testw 1.4 or F3 ?
I had the same problem with toshiba 32GB, I traded it with a friend for old 16GBs card and it worked.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 20,911 Yesterday, 11:55 AM
  PXE Boot example? lewis 7 18,102 10-08-2025, 06:51 AM
Last Post: LewisHenderson
  How to boot an older, working kernel bits 0 3,006 11-01-2024, 04:43 PM
Last Post: bits
  problem with debian emmc boot G4zCDzWb 10 30,613 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 4,937 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  Rock64 won't boot dstallmo 0 3,355 12-27-2023, 10:34 AM
Last Post: dstallmo
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 4,975 06-02-2023, 07:52 AM
Last Post: diederik
  Disabling last mount time check on boot acwest 0 2,329 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 13,936 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 2,862 06-27-2022, 06:52 PM
