Kernel Panic on Rock64 linux
Video
About My Rock64 occurred kernel panic.
I bought four Rock64 board.
2 of 4GB model,2 of 2GB model.
Other 3 boards works well.
One of 4GB model occurrd this problem every time.
Im using newest xenial-minimum and xenial-mate on MicroSD.
Power supply to GPIO 5V and GND by iPad Pro's 5V 2.4A charger.
But other 3 board work well under same MicroSD,OS image,charger.
So I think comatibility problem(or initial failure?)
movie:xenial minimum on microSD
pictureConfusedame(https://drive.google.com/file/d/0B58MjMV...sp=sharing)
I know how to fix this problem.
Sorry my bad english and Thank you forum member
Does the board panic using all SD cards ?  If so, and if all SD card work in the other boards, then we can assume a hardware failure this one board;  open a support ticket.
Before you do that;  check the board over with a glass, or scope (eye piece),  to determine if any solder balls are left on the board from mfg;  this does occur unfortunately ( I actually had one board with this problem ).  Carefully check all spaces, pins, around all chips, in every connector;  also look for solder bridges.
(08-25-2017, 12:49 AM)MarkHaysHarris777 Wrote: Does the board panic using all SD cards ?  If so, and if all SD card work in the other boards, then we can assume a hardware failure this one board;  open a support ticket.
Thank you for reply.
I tried samsung,toshiba,and sillicon power Micro SD card.
But it is not changed.
I saw using ocula glass,I look for solder bridge around surface mount resister.
But I dont know this is cause of this problem or not.
can you post a close-in pic ?
I suspicious this https://drive.google.com/open?id=0B58MjM...Vp3RFI4SkE
Yes,  that is definitely a problem, but easily fixed !
But How to fix it?
(08-25-2017, 08:11 AM)tanisou Wrote: But How to fix it?
Its actually very easy ( really ).
... you use a 25 watt soldering iron and a tooth pick.  A hot air gun soldering station would be better, but if you don't have that ( they are pricey ) don't worry about it.
Basically you het the component carefully and you use the tooth pic to push it over where it belongs !
The pick&place robot slipped, or the component slipped in the oven. If you heat it and move it back it may work.  Depends on whether any damage occurred.
Make sure YOU don't create any solder bridges ( you can used solder braid to clean it up if you do ).
( just don't do that )
Give it a shot;  like my old boss used to say, you can't break broke.    Blush
Thank you for teach me method.
I tried to fix it.
pic: https://drive.google.com/open?id=0B58MjM...1FJVVM4X00
After fixed it,I turn on Rock64.
But displayed same kernel panic error...
And I notice this spot become hotter than SoC chip.
https://drive.google.com/open?id=0B58MjM...1VVTlZMTEU
https://drive.google.com/open?id=0B58MjM...F9ZSncxeWs
(08-25-2017, 07:26 PM)tanisou Wrote: Thank you for teach me method.
I tried to fix it.
well, you gave it the good 'ol college try !   open a support ticket and get that thing replaced .
  Rock64 v2.0 u-boot SPI issues ju0n 1 960 09-25-2026, 11:19 PM
Last Post: mysy
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,285 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 29,093 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,086 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 19,165 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,974 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,134 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,146 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,533 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 5,023 11-28-2022, 02:18 PM
Last Post: Macgyver
