Problems using Spotify Web version because DRM (Firefox & Chromium)
Music
Hello.
I'm trying to use Spotify Web version, http://play.spotify.com.
I tried on Chromium and Firefox, but both cases I'd been redirected to a Spotify message saying (for me in spanish, try to write on english): "The play of DRM content is not enabled" and a link to a how-to for both navigators:
https://support.spotify.com/es/using_spo...eb-player/
I have the configuration in Chromium that says the article, but still getting the same message.
In Firefox there are no option like said in the article.
Anyone knows how to use Spotify Web? (cause no ARM .deb version from the application)
Thanks.
Anything new?
I asked it on our IRC channel (#pine64)
And they told me this:
there is an open source port of libspotify
Spotify stopped supporting ARM a while ago
Volumio is using that for example
https://github.com/plietar/librespot
(08-14-2017, 05:56 AM)Pepe Wrote: Hello,
Great, I will try it for sure, thanks!
Ok, it is not usable, build failed.
error: Could not compile `unicode-bidi`.
I had a similar case at Amazon music. I couldn't play any music before changing the User Agent. In my case, Setting the UA as Edge 13 (or 12). Why don't you try to change the UA? It might be a solution. Good Luck. Cool
Hi, is this solution? I think you can try to change your account location in USA on Spotify web player and then try again.
  Flakey WIFI (problems authenticating, etc.) robbiemacg 6 14,490 12-15-2019, 04:31 AM
Last Post: matze79
  Firefox and youtube playback Luke 15 40,276 07-25-2019, 01:31 PM
Last Post: MrTester
  Problems putting Ubuntu (Xenial Mate) on my replacement eMMC. frank-zappa 11 24,071 05-01-2019, 12:09 PM
Last Post: frank-zappa
  Chromium OS? Devilotx 4 12,139 01-31-2019, 03:19 AM
Last Post: soupbowl
  KDE Neon problems persisting (1080) ImmortanJoe 8 15,583 11-18-2018, 02:22 AM
Last Post: ImmortanJoe
  Problems to install qemu on Xenial Mate (for EMMC) demian 1 5,419 03-14-2018, 08:43 AM
Last Post: xalius
  Installing VS Code (& Chromium) Prophesi 21 48,874 09-13-2017, 03:27 PM
Last Post: DigitalStefan
  Disable pinch-to-zoom in chromium angry_elf 15 30,775 08-31-2017, 06:00 AM
Last Post: combs
  Problems At Shutdown? robbiemacg 10 19,372 08-25-2017, 10:20 PM
Last Post: MarkHaysHarris777
  Chromium for Q4OS q4osteam 0 4,237 06-21-2017, 08:09 AM
Last Post: q4osteam
