First images with DRM and Mali support for A64
#41
(07-22-2017, 06:30 PM)Luke Wrote: After some mindless trial and error I got Retroarch working Smile
How did you download a core?
#42
This will install all cores. Alternatively specify core instead of *
sudo apt-get install libretro*
#43
Thanks, it works. Sonic the Hedgehog running, just not so smooth like on real Sega Genesis or my PC Smile
I also wonder why even Atari 2600 games do not run smooth in full screen mode.
#44
It takes a lot of tweaking to make everything run smoothly. If you have a Pine64 board then just try this - I did all the hard work for you. Its a heavily modified ubuntu image that launches an optimised Retroarch build on boot (note that exiting Retroarch powers down the board).
#45
(07-24-2017, 06:51 AM)Luke Wrote: It takes a lot of tweaking to make everything run smoothly. If you have a Pine64 board then just try this - I did all the hard work for you. Its a heavily modified ubuntu image that launches an optimised Retroarch build on boot (note that exiting Retroarch powers down the board).
I have Pinebook only, so I think I will not use this, but thanks anyway.
#46
I wonder why is 2D graphics so slow when DRM is enabled and fast while it is disabled. I see the difference mainly when moving the windows etc. in KDE Plasma.
#47
(07-25-2017, 01:22 AM)Wizzard Wrote: I wonder why is 2D graphics so slow when DRM is enabled and fast while it is disabled. I see the difference mainly when moving the windows etc. in KDE Plasma.
Yeah, I noticed that too... DRM sucks when just doing normal desktop-y stuff (there you go tkaiser... that's the benchmarking for you... it sucks :-P - and it will have to remain empirical benchmarking for now as the  tools I've tried so far don't wanna work on the pinebook) ... but now that there is a proper enable/disable script (thanks ayufan!) I'm leaving it disabled and re-enabling my nice software composition effects Wink... too many white flashing boxes and other artefacts just doing things like dragging a window or opening a caja window for me to warrant leaving it on for everyday use. But that's fine for me atm... I don't do anything that warrants needing DRM AND 'normal' 2D performance atm, so I can live with that.
#48
Can you check how it works with fbturbo?
I would expect the performance to be roughly the same, as it doesn't really differ.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
#49
What is fbturbo?
#50
Wizzard, since you were keen on trying retroarch on the Pinebook please run this script on a ubuntu minimal image Smile
  Official Debian support! Luke 85 211,774 02-18-2026, 12:58 PM
Last Post: kapqa
  official support for aarch64 in OpenArena Opvolger 0 5,665 03-24-2022, 02:23 PM
Last Post: Opvolger
  Fedora 32 Release, improved support for Rock(Pro)64 Tharadash 2 9,162 05-05-2020, 08:37 AM
Last Post: zer0sig
  Kickstarter: Allwinner VPU support in the official Linux kernel xalius 8 22,274 10-03-2019, 03:03 AM
Last Post: bunkerWHz
