Q4OS for PINEBOOK
#31
@zer0sig
You can also mount and copy Q4OS image using any Linux computer this way:
sudo kpartx -av q4os-pinebook-1806.img
sudo mount /dev/mapper/loop0p2 /mnt/some_mount_point/
Copy "pinebook-q4os.img" from /mnt/some_mount_point/pinebook-q4os.img, and remove loop:
sudo umount /mnt/some_mount_point/
sudo kpartx -d q4os-pinebook-1806.img
Now you can flash "pinebook-q4os.img" to a SD card.
#32
New Q4OS for PB release "1806" is available for download:
https://sourceforge.net/projects/q4os/files/stable/
News and fixes included:
- Q4OS now runs directly from SD Card
- Optional installation to eMMC available, just clicking to a desktop icon
- Chromium browser installer in the Software Centre
- Screen dimming and powersave modes tuned a bit
- System updates and other minor fixes
Initial credentials:
user: adminq
pass: adminq
#33
Thanks q4osteam, looking forward to test this release...
#34
Any feedback is appreciated Smile
#35
(07-02-2017, 06:23 AM)q4osteam Wrote: Any feedback is appreciated Smile
Q4OS is running fine and does use less memory ike Ubunu Mate :-)
Two first things:
I got Video playing in VLC only via the slow X11-Driver (no VDPAU) - will there be better GFX-Card Suppport?
and
renaming Iconson the Dektop works onl in the second try (not ony on Pinebook - also on a x86 Laptop and RPi3)
But Chromium and Firefox is very useable :-)
I like the MATE-console- and it could be installed without problems :-)
#36
Chromium and LibreOffice in Software Centre can not be installed, version 1806.
#37
(07-16-2017, 11:21 PM)sujunmin Wrote: Chromium and LibreOffice in Software Centre can not be installed, version 1806.
any error message? As which User did you try to install?
#38
adminq, and it says could not connect to network, but I have connected my wireless already.
BTW, I saw the kernel is used ayufan' kernel, and could we use latest ayufan's kernel? How can do that?
#39
If you open a text-console/shell, did ifconfig tell you that you got a IP from your network?
Did you use DHCP or static IP?
Can you ping 8.8.8.8 (DNS of Google)?
#40
(07-08-2017, 04:59 AM)guidol Wrote: ... renaming Iconson the Dektop works only in the second try ...
@guidol
Thanks for that report, however I am not able to reproduce so far. I would need to get more detailed description and procedure to reproduce.
I can make and rename new desktop shortcut, for example, this way:
- Open Start menu and navigate "Applications > Programs" folder
- Drag "Terminal Program" icon and drop it elsewhere to desktop, a context menu appears
- Select "Copy here"
- Now I am able to rename the desktop icon using "right mouse click > rename" or "F2" key
Please specify some more details for us to be able to reproduce and fix the issue you have described.
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 3 11,965 11-28-2025, 07:38 AM
  DietPi OS for Pinebook MichaIng 3 12,284 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 89,511 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 4,215 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 3,192 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 11,808 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 6,160 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 8,016 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 8,700 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 6,416 01-20-2021, 11:18 AM
