[Question] Migrating to Pine64.
I have a few collection of SBC's and some are running the OLD Raspbian Wheezy. My question is simple, is it possible to migrate from one of the other boards to the Pine64 by simply moving the microSD card? Or is there another way? I need a little more kick for my servers, I think the pine64 is a safe bet.
Thank you.
No. Simply moving sd card will not work. You could probably move the root filesystem (minus kernel related things) and that could potentially work. It is difficult to say would your software run without knowing more about it.
It's not running anything with the GPIO's, it's all software related stuff like NAS server with samba.
(03-01-2016, 07:04 AM)VectorJones Wrote: Hello,
The Pine64 is a different architecture than something like an Raspberry Pi.  @janjwerner points out that there is a way to copy the rootfs over, I think that is more hassle than it is worth because problems might be hard to diagnose unless you really understand Linux internals.
In general, I think that you would be better served to start over.  I have done this in the past and the good news is that basic things like config files can be reused.  In my experience the best way to do this is to run the two systems in parallel while you get the Pine fully operational.  (This always gives you the opportunity to compare and/or copy over config files.)  Once the Pine is ready then you can switch over. I would further add that I use the same process when migrating between RPis since I typically migrate between different generations. (e.g. I last went from a Pi B to a Pi 2)
My $.02.
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 10,563 10-21-2025, 10:13 AM
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,820 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 7,221 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just discovered Pine64 ! - first Q philip_rhoades 4 10,436 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 6,694 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 217,499 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 15,475 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 23,310 03-28-2019, 11:43 PM
Last Post: InsideJob
  Pinebook Pro NVMe Question Selden 6 16,125 03-25-2019, 05:36 AM
Last Post: Luke
Information Creating a NAS server in Pine64 javi_cala 4 12,622 01-21-2019, 02:03 AM
Last Post: bartes
